4 in exhaust question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-14-2011, 06:45 PM Thread Starter
adavis11's Avatar
I have an early 99 7.3 and am going to order a turbo back system. Do I need to look for a specific exhaust or do the systems fit both early 99 and late 99. I was just wondering because im pretty sure the early 99 has a smaller trubo and I did not know if the down pipe that connects to the turbo is the same size on the early 99 and the late 99.
adavis11 is offline
post #2 of 7 Old 07-14-2011, 08:41 PM
venturesomerite's Avatar
I just installed a MBRP 4" straight pipe single exhaust by myself on my e99 in a lil over an hour the other day, just ordered a kit for a 7.3, no specifications. Most of that time was getting the band clamp off the stock exhaust and dicking around with it to get it as far from the rear shock as I could. Over all very easy to install.
E99 SC LB 4x4 auto 7.3
Glow Shift gauges, pillar pod,column pod, Hutch, harpoon, 05 headlights,HPx, FRx, Napa Air Filter, 4" turbo back MBRP straight pipe,CCV, 1 ton crane on bumper, Reading flip top utility body, jersey bars, Modified/ strengthened Vangaurd Ladder rack, telescopic work lights, reverse facing flood lights, quad fogs
Future mods: on board air, inverter with outlets in bed
venturesomerite is offline
post #3 of 7 Old 08-03-2011, 10:06 AM
Ive been trying to get that clamp off for over an hour and it wont budge, I sprayed the h**l out of it with pb blaster and it will not move, I was gonna cut the exhaust by the transmission and try to wiggle it loose but didnt want to risk not being able to get it off that way either! any tips, pointers on what else to do? Its a late 99 with stock exhaust so I know there is lots of arbon and build up in there!
wrx600rr is offline
post #4 of 7 Old 08-03-2011, 12:39 PM
I ended up taking a flat head screw driver and bending the clamp slightly to get it off, just use some plyers to get it back in shape once its off. I cut my exhaust off in two places, just after the cat and at the bend of the down pipe, no problems getting it out. If you also cut it after the axel it will be even easier.
post #5 of 7 Old 08-03-2011, 01:13 PM
SOHCPOWER's Avatar
Were you guy's having problems getting the v-band clamp off the turbo? The best way to get that one off is with an air hammer. Or a long punch and a BFH will knock it loose every time
2000 F-250 7.3 CCSB 4x4 7.3
2007 F-550 CCLB 2wd 6.0
2003 F-550 Reg Cab 2wd 7.3
2003 F-350 CCLB 4x4 76.0
7.3 powerstroke repair/enthusiast for ten years.
SOHCPOWER is offline
post #6 of 7 Old 08-03-2011, 06:36 PM
Ive tried pb blaster and about 2 hours of tightening and loosening it, I pried on it with my flat bar but it just wont come loose! I am gonna try to cut the downpipe tomorrow after I loosen the band again and hopefully it will vibrate loose on its own! I might have to get under it and kick it a little also to help it pop off! I dunno, Im ready to just take it to a shop before I hurt myself out of frustration, LOL!
wrx600rr is offline
post #7 of 7 Old 08-04-2011, 04:17 AM
SOHCPOWER's Avatar
You have to strike the v-band to knock it loose. I've spent hours trying to pry them off and it won't do anything. One carefully placed blow with a pry bar or long punch right on the V part will get it off. It will basically explode off of there. The same technique goes for getting the v-band off of the y-pipe. It will work....
