Just installed
Yesterday my muffler split so I made this muffler delete setup what do you think?
A+ for creativity.... but I'm sure in NY the Po-Po will not like it.
Does anybody like the way it looks? Yes- No, do I need to give it slash cut ? Opinions please good or bad no hard feelings Thank You
lol i like but like said thats not much pipe im sure its plenty loud.. mines all the way out back at the stock location not too loud compared to less pipe.
what kind of pipe is that? Looks like you took 2 pc of sheet metal and bent them almost in a circle and welded them to make the pipe... kinda ovaled... Personally, I'm not crazy about the look, and you'll get soot all over the rear tires... might slash cut the end parelell with the side of the truck... Just my opinion.
That flex pipe doesn't last long... I have it on my Crapalier's exhaust, and it rusts through every few months.
Everything thing is stainless steel and tig welded not worried about rust. Not sure if I like the noise, if I keep it I will put a slash cut parallel with the fender.I still have the section from the end of the muffler to the stock location, I may just reinstall it with a muffler delete pipe.
Looks great! I dumped mine before the axle for a couple of weeks. The drone in the cab was too much so it went out the back. I also run a topper/camper shell which probably makes the noise worse.
Updated picture with slash cut
Looks alot better now
