flywheel ????
i recently found an amazing deal on a 2000 4x4 f250 7.3l with 165,000 miles on it and in great shape, and i am realy interested in it but after i emailed the guy about it he said it has a cracked flywheel
...how big of deal would it be to fix this ? i would appriceate any help thanks alot !
Drop the tranny and replace. Just a few bolts (5 i think) holding it to the motor. Pretty straight forward.
also any idea as to what this might cost if i have it done by a mechanic (roughly) ? thanks alot
you can typically figure an hour out and an our in. Add an hour for flywheel and other misc. Assuming you dont go to a diesel specific shop (theyre more expensive and not needed for this) most shops are around 80 an hour near me. I cant imagine somebody wouldnt do it for under $300. Where are you located?
the guy said the truck is a regency package and loaded and he wants 7000 for it ... would it still be worth buying it ? and what is a regency package ?thanks
It's a stick shift truck right? Cracked flywheel or cracked flexplate? How would the guy know he has a cracked flywheel?
The automatics have some issues with cracking the flexplate, which will cause a horrible rattling sound at idle. Also 4 wheel drive or 2 wheel drive? If you can replace a 4 wheel drive flywheel in under 3 hours you're a bad mother huncher. It's the same labor as doing a clutch job. I would say anywhere from 4-6 hours is more accurate. Not saying that it will really take someone that long, but that's what a shop is more likely to charge you hour wise. |
its a 4x4 automatic .... and the guy just told me it was the fly wheel cracked idk how he knew thanks
