Instrument Panel - Ford Powerstroke Diesel Forum
Old 07-05-2011, 03:06 PM
Instrument Panel
2000 F250
None of the gauges work on my instrument panel. I have checked all fuses under the dash and under the hood. Both fuses 41 and 45 were good
Removed the steering wheel column cover and check the wire coming from the overdrive it was good (taped it for preventative maintenance)
My instrument panel is receiving the power. (measured 12v coming in).
I checked all the connections on the flexible circuit board and could not see any breaks in the connections.
I believe that my instrument panel is actually broken. However I could have have missed something due to my frustration.
If I have to replace the panel I would like to use an aftermarket custom.
Simco Ltd. Specialty Instrument Clusters, Components, and Driver Information Display Engineering and Manufacturing very nice instrument panel for the F250 but they don't have one for a diesel
CARiD.com - Car Accessories, Truck Accessories
Are there any other places that make Instrument panels for my truck (digital if possible)
curious to know:
Is there a way you can put a 2010 panel in my truck
Your help will be appreciated
Thank You
