20mm freeze plug delete - Ford Powerstroke Diesel Forum
Old 07-04-2011, 11:11 AM
O.I.F. Combat Vet 11B
I just wanted to get with everyone and make sure I did this correct. Here are some pics, I just drilled out the rivets on the flapper and pulled the piece out the hole. Took my dremal and cleaned everything up and used it to round out the opening where the plug goes to help get her started. Overall pretty easy to do and hopefully will get the 50 degree less egt's I have read about.
Old 07-04-2011, 11:19 AM
Feedback Score: 5 reviews
I had to file down the plug a little bit to make it fit... Wouldn't go at all. Took me a bit bit I eventually drove it home with a socket/hammer/smashed fingers.
Old 07-04-2011, 11:30 AM
did you notice lower egt's?
Old 07-04-2011, 01:13 PM
I would say yes, but it's not easy to tell. More watching the road than the gauge when getting that hot... but I haven't seen over 1200* in a while.
Old 07-04-2011, 06:10 PM
So this is also needed if u get a pedestal without the EBPV?
Old 07-04-2011, 06:24 PM
Cool Outlet
Boy I hate to see all the work you have to go through to end up with 1/2 fix. I know the hole is 2.7" and theres such a big differance changing up to the 4". I read an artical about somebodys hot new turbo and they gave the spec's on what it would do and then installed it with the stock housing.
Old 07-04-2011, 09:37 PM
was easy to do, how much are the bigger housing and where can you buy them? Might upgrade when the money is right.
Old 07-05-2011, 08:57 PM
not bad.. mines just welded up, lol not pretty but it worked too.
