XL cruise control
Is their any easy and quick way to make my 2000 XL have cruise control?
I would also like to know what is needed to use cruise on an XL. I installed a cruise wheel hoping that was all I needed, but this is not the case. What other parts do I need? Thanks.
Cut a few 2x4s to desired length to wedge between the seat and pedal.
Have on for 60,65,70,75 then u have options. |
Ford Superduty Diesel OEM '99-'01 A little pricey, but it comes with a new steering wheel. I got a kit for my e250 motovan gasser. It works really well. |
Cruise Control
For instructions on how to use your Brick for other wide-ranging tasks, buy The Brick Manual today! Cruise Control: Brick Manual Sample |
Call him up, he'll sell you only the parts that you need.
I just put cruise, and tilt on my truck. I bought a lariot steering column from a junk yard for $120.
Took me a few hours to remove my old column, and replace with the new one but way cheaper than $400. And I have a leather wrapped steering wheel, and tilt. |
You need to complete the circuit where the cruise deactivation switch would be located on the master cylinder. You may also need a new clock-spring. I'm not 100% on the clock-spring.
Mine is controlled via the vehicles ecm. My truck's wiring harness was already equipped with the necc wires. All i had to do was plug into the harness. (My truck is drive by wire though)
