Removing trackbar mount - Ford Powerstroke Diesel Forum
Old 06-29-2011, 04:48 AM
Send a message via AIM to tristanlee85 Send a message via MSN to tristanlee85 Send a message via Yahoo to tristanlee85
I am trying to remove the trackbar mount so that I can install the new one that came with the lift kit. On the bottom of the frame rail where 2 bolts go in, one of them feels like either the nut behind it is spinning when I loosen it, or the threads are just ripped off the bolt while trying to loosen it and it will no longer thread out. I can't figure out how to access the nut that's inside the frame though to see what's really going on. Any ideas on how I can get this bolt removed?
Old 06-29-2011, 04:57 AM
Feedback Score: 5 reviews
I had the same problem with mine. The nut is made onto a flimsy bracket. We ended up cutting mine and buying a new one
Old 06-29-2011, 05:10 AM
I take it you just cut the head off the bolt and took everything out through the frame area? I'm not sure how to access back there unless I have to remove the steering box or something.
Old 06-29-2011, 05:18 AM
We cut the bolt off even with the bottom of the frame. I had to use a hammer and a punch to knock the bolt out of the hole. Then, I took the front bumper off to remove the bolt. Mine was all twisted up in the frame from trying to get it out
Old 06-29-2011, 05:25 AM
Fun fun... I suppose I will give that a shot. Thanks!
Old 06-29-2011, 08:06 AM
I heated the nuts up inside the framerail w/ a map gas bottle I got from home depot. I think the nuts have a dab of locktite on them. Just started heating, stuck a wrench on the bolt head & they came out w/ no problems
Old 06-29-2011, 08:07 AM
I got mine broke loose and I can spin it to loosen it, but it does not thread itself out. I am thinking that perhaps the threads stripped themselves off in the nut or something and there's no threads to extract with... no idea.
Old 06-29-2011, 08:09 AM
The nut is probably broken loose from the bracket. IIRC, we couldn't get a wrench in there to hold the nut, so that's why we cut it off
Old 06-29-2011, 08:10 AM
Did you get a new nut/bracket from the dealership or just use a new nut and bolt from the hardware store and tighten it down with the bumper off?
Old 06-29-2011, 08:12 AM
I bought a new one at the dealer
