fuel filter
how often do you change the fuel filter? I am about to change my oil with some rotella, I am about to turn 99000. What else should I do as far a maintaince right now at this point?
fuel filter should be done every 15k...
trans every 30k, as well as green coolant. Its never a bad idea to change your powersteering fluid out, or service the transfercase or diffs if they have never been done... |
since I dont know if the tranny fluid has ever been changed I probablly shouldnt fool with though right? That is what I have always thought anyway.
no...if your unsure i would do it for sure. Drain the pan, replace the filter, and drain the torque converter...
I agree with Marc on the replacing the filter, and draining the torque converter and I would put in a good name brand Synthetic oil that is made for your transmission.
how do u change the filter? the fluid looks good. i will see the filter as soon as i take the pan off right? i am thinking about getting a different valve body ithink it is called the grid that fluid flows through so i might wait until then to replace all the fluid since i will have to drop the pan anyway
