what is best lift to run 37s - Ford Powerstroke Diesel Forum
post #1 of 15 Old 06-26-2011, 01:02 PM Thread Starter
I have a stock 2003 f-350 ccsb what size lift is needed to run 35s or 37s not sure which ones yet. would like to get info on how much lift suspension is needed for both sizes. also which is the best brand kit to use? Any pics with these lift / tire combo would be helpful. thanks
da476 is offline
post #2 of 15 Old 06-26-2011, 01:26 PM
Bend6.0's Avatar
Tan One: 3" w/35" tires
White: 5" w/35" tires.
Both on 16x10 powder coated aluminum
Generally, 4" for 35's and 6" for 37's
I don't really have any preference in brands of lift, they all seem to ride the same to me in the front.
ID:	26471   Click image for larger version
ID:	26472   Click image for larger version
'03 F350 CCSB 27k
6spd,SCT Livewire
285/75/16 +2"front
RCD EGR Delete,AEM Intake
Sold:
'06 F350 CCSB 87K
6spd 4x4manual hubs
6"Fabtech w/35"s
'01 Stroke CCSB 112k 6spd
5" lift, 35" tires 4" straight
NAPA 6637 Intake, Wicked Wheel
TS T6 Pyro/Boost Gauges
AIH/EBPV Delete
2005 6.0, 2001 7.3, 2-'99, '97,'96,'95,'92IDI, 3-Cummins
Bend6.0 is offline
post #3 of 15 Old 06-26-2011, 03:07 PM
Chapter Director
freeride707's Avatar
At least 6" is needed for 37s leme know if your interested in lifting your truck. I'm going down to a 4" and 35s. Pm me and we can work a price on my procomp 6.5" lift and 37s on 20s with only 5k miles.
E99 F250 7.3l CC SB 4x4 Lariat,8.5" lift, dual reservoir shocks toyo my 37's gear alloy 20x12's,TW chip,5in exhaust,DIY intake,BTS trans,HPX, frx gauges,Powerslot rotors w/hawk pads,Tint,08 emblem vents,Custom paint,05 Harley front w/ custom grill, shaved 08 step gate and tinted tails, spray-in bedliner
WCS Assistant Director
freeride707 is offline
post #4 of 15 Old 06-26-2011, 04:57 PM Thread Starter
both of those trucks look good. thanks
da476 is offline
post #5 of 15 Old 06-26-2011, 05:01 PM Thread Starter
looks good. i will pm you
da476 is offline
post #6 of 15 Old 06-26-2011, 05:48 PM
Zaairman's Avatar
Quoted: 12 Post(s)
I have an add a leaf up front and am running 35s...
Minor rubbing on the plastic inner fender, but nothing that can't be fixed with a dremel or heat gun...
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #7 of 15 Old 06-27-2011, 04:59 PM
4in on 37's pics in sig. before anyone else says it doesn't work, ..it does
2000 f350 CCSB
4" MBRP TURBO BACK Muffler Deleted
S&B Cold Air Intake
4in. Superlift w/Billstein 5100's
Dual Steering Stabilizer
18in. Granite Alloy Wheels
37x13.50 Toyo Open Country M/T's
bigsho is offline
post #8 of 15 Old 06-27-2011, 05:08 PM
Chapter Director
Where's it rub at? My 37s rub in certain situations front and rear... And I have 8.5" lift
post #9 of 15 Old 06-27-2011, 05:48 PM
rear never, front on the leafs at full lock. but i have a diff offset check out how the wheels stick out.
2000 f350 CCSB
S&B Cold Air Intake
bigsho is offline
post #10 of 15 Old 06-27-2011, 06:07 PM
Chapter Director
You must not go offroad much? My wheels stick out about 3" past the fenders they are about 1/2" from hitting leafs and rub on the fender while turning and hitting a bump but not always.
