4 low problems - Ford Powerstroke Diesel Forum
Old 06-25-2011, 06:36 PM
4 low problems
I have an 2002 f250 super duty 7.3 liter auto that will not go in 4 low 4 high works fine but no 4 low any ideas?
Old 06-25-2011, 07:00 PM
Do you have an electric shifter?
Old 06-25-2011, 07:11 PM
do you shift the transmission into neutral when you try to shift it?
Old 06-25-2011, 08:18 PM
yes it electric and yes i have tried it in park in neutral and nothing seems to work the 4 low light never comes on the 4x4 light does but not the 4 low?
Old 06-25-2011, 08:34 PM
I've seen several friends' switches go bad. One guy pulled it out and jumped the connections to fix it temporarily.
Old 06-27-2011, 01:25 AM
i dont have a wiring diagram so i would be afraid to do any jumping without one
Old 06-27-2011, 02:16 AM
Feedback Score: 7 reviews
I can post the wiring diagram if you need it. Let me know!
Old 06-29-2011, 07:00 PM
I've heard of the motors freezing up due to not using them very often. try tapping on it lightly with the truck in neutral while someone switches it over.
Old 06-29-2011, 07:05 PM
I'd be careful doing that-While the truck is driveable as it is, if you get it in 4 low without fixing the issue, getting it out will be an ordeal, and it will not be drivable.
