2cycle oil - Ford Powerstroke Diesel Forum
Old 06-22-2011, 09:56 AM
2cycle oil
well i tried the 2 cycle oil in the fuel tank, WOW did it make my truck quieter. stopped alot of that clatter i was having. hope its not bad for truck cause i could get use to it being less clattery (not sure if thats a word)
just thought i would let yall know
Old 06-22-2011, 10:10 AM
How much did you put in? I've read that perhaps a quart on a tank full?
Old 06-22-2011, 10:28 AM
Usually it's 1oz per gallon....so yeah full tank could see a quart.
Old 06-22-2011, 10:36 AM
Using 2-cycle oil doesn't harm anything else? I've been adding Power Service each time I fuel up. I used to own a 05 Dodge with the quiet diesel, and this 7.3 PS is really noisy in comparison, so if 2-cycle oil quiets it down some ... I'm for it but also don't want to cause any long range problems down the road a couple of years ...
Old 06-22-2011, 10:43 AM
I used it for quite a while with no ill effects. I think at the dilution it is, it shouldn't cause problems. I look at this way - It's used in 2-cycle engines all the time diluted with gas....should diesel be much different? That's just me thinking. I'll stop before I get a headache...
It does quiet things down 'a bit' - Don't expect it to be super quiet, but it's noticable. I, too, use DK most of the time.
Old 06-22-2011, 11:39 AM
i dump 2 quarts of 2 stroke oil in everytime i fill up which is about 25-30 gallons....runs smoother and a tad quieter
Old 06-22-2011, 12:37 PM
little less than a quart. i didnt fill all the way up. it was my first time adding 2cycle.
Old 06-22-2011, 07:08 PM
just got back from the store and i just cant believe how smooth my truck is from that oil. does anybody know why that is? i want to in the future to run bigger injectors will they be quiet or the bigger the louder?
Old 06-22-2011, 11:12 PM
because the ULSD our trucks are forced to run out lacks alot in lubrication.. so therefore it helps...
anyway yes they will be because most upgraded injectors are all single shots.... quite noisy lol
Old 06-22-2011, 11:44 PM
we could fill our tanks with two-stroke oil and run on it.... just saying. wont hurt nothin either... might clog a filter though
