best oil?
i just bought my 00 f250 and it needs a oil change this is my first powerstroke and i have no idea what the best oil is, ive always use royal purple on all my gas trucks! and i can tell you this stuff is great! keeps my motor sooo clean! but ive heard that its not very good for diesels what do you guys think?
should i start putting purple in my powerstroke?? (300k motor) thanks! |
Well, here is my vote - I say you go for 5-40 rotella synthetic oil. You can get it at wal mart for 20 bucks a gallon, and you need 4 gallons. In the same isle, buy a motorcraft filter.
Change oil every 5k with synthetic rotella and your truck will be happy and super clean. Oil analysis always comes back great with the rotella, saying I could go much longer between intervals. Lots of opinions here, but I say save some money and go with the good stuff. I used to put RP in my dirt bike, my truck... not really a fan. Scott |
silveradobeast-----I was just in the same boat as you, I am a new 02' F250owner and researched about the same question you ask. Most of my findings were just as Scotty tells, Rotella Syn (T6 in blug jug think it was) and Motorcraft filter is what I did. Good luck!
RP sux, it doesn't hold it's viscosity.
If you want dino: Go Delvac. Cheaper Synthetic: Rotella T6 Best IMHO is AMSOIL. I'm running Amsoil at 10k intervals right now. |
I'm a big fan of T6 Rotella, can't beat it for the price. Mobil 1 TDT is also great full synthetic, and Schaeffer's Supreme 7000 15w-40 semi-synthetic is another great oil. Of course, Delvac, Rotella T, and Delo are going to be just fine in your truck too. I would also stay away from RP, I've used it before and given it a few chances and just wasn't impressed with the UOA's it produced.
If you switch over from dino to synthetic oil is there any truth that the synthetic will clean the gunk out of your engine. Probably a dumb question, but if this is true, do you need to change the oil filter more often during the switch over so it doesn't get clogged up and perhaps stop working? Such as perhaps every 1000 miles during the first oil change ? I bought my 01 with over 140k miles and my guess is it's never had synthetic oil in it ... and I would like to make the switch. Using a 5-40w sounds like a good idea and would sure help the winter starting here in South Dakota....
Just make sure that whatever oil you use that it has a CJ4 rating.
You won't have any trouble switching and your truck will LOVE it come winter time. My truck used to 'romp' when it was really cold out on the 15-40, but starts right up, no romp when cold when running 5-40. Your truck will run smoother, quieter... maybe slightly more mpg... can't go wrong, you will love it. Scott Scott |
rotella 5w40 syn
