need some wheel help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-08-2007, 04:51 PM Thread Starter
moving to new wheels... switching from 16.5 with my 35's to 18x9 with 37's. Know the bolt pattern is 8x170, however what should I use for offset, backspacing and hub diameter? Ive got a few options...
My wheel options are:
# Back Spacing = 4.52 in.
# Offset = -12 mm.
# Hub Bore = 125.5
# Back Spacing = 5.18 in.
# Offset = 30 mm.
# Hub Bore = 125.5
# Back Spacing = 5.70 in.
# Offset = 18 mm.
# Hub Bore = 125.5
Thanks
2001 Excursion
PHP Hydra, Insight CTS, Intake, RR Boots and plenum inserts
345,000 miles and counting!
fulloutpwr is offline
post #2 of 2 Old 08-08-2007, 05:24 PM
99CrewPSD's Avatar
my 22's are 5.65 inch backspacing,10mm offset and 125.5 hub.....imo they sit in the wheelwell just right.
2001 ECSB F250
Little bit of this and a Whole Lot of THAT
99CrewPSD is offline
