Trailer Wiring Issue - Help
842 views 5 replies 4 participants last post by  twin200
#1 ·
Perhaps I posting in the wrong area. I am not getting a brake light or blinker on the right side of my trailer. All other lights/running lights are working as they should be as are the electric brakes. It's not the trailer wiring, I've been able to trace the problem to the wiring harness up near the firewall. When I unplug at that point and check the terminals feeding this harness, I get very low juice on the right blinker (barely registers (less than a volt)). So something must be wrong somewhere else ... is there something under the dash I should be checking / changing? Any ideas on what to check next? Thanks ...
#6 ·
I had the same problem some years ago and it took a long time for me to find this problem as I was not a member here.This place is great,all you have to do is ask:thumb:
