I had this posted in Powerstroke problems but didnt get any help so im movin it over here
Ok so today i was hauling brush. I backed into the yard which is kinda rough so the truck was gettin knocked around a bit. So i shut the truck off and got out and everything, got in to leave and the truck wouldnt start. It will sit and turn over fine but just wont fire? So my buddy pulled me outta the yard and we came to the conclusion that the truck wasnt getting fuel. We climbed under the truck and turned on the switch and the fuel pump wasnt turning on so we figured it had to be the fuel pump.. but would a fuel pump really die that sudden? After thinking it over i came to another conclusion. Could it be the crankshaft positioning sensor? To the best of my knowledge this sensor will cut off fuel to the motor when it goes bad (or rattled loose). Im going to replace the sensor tomorrow and see what happens but does anyone have any other ideas? On a side note, if it is my fuel pump then im looking to upgrade. Does anyone have any input on a good aftermarket fuel pump? |
I had a CPS go out after some really rough running last year. That could do what you described.
When you are trying to start the truck, are you getting smoke out of the exhaust? If you are then it's getting fuel, if not, no fuel. If you are getting smoke/fuel then I bet it is the CPS, if not I bet it's the fuel pump. Although I am on my third pump and third or forth CPS and all went out traveling down the road. So the fact yours quite while sitting?? I don't know??
And whats the CPS? |
Cam shaft position sensor. Cost about $15.00 to $20.00 from any parts store. I think fords are now $28.00. They had a recall on them about a year or two ago and replaced them all. Sounds like yours may have not been replaced. Takes about 5 minutes to replace. I would try this before I take it to a shop. This is probably your fix. It is located on the front of the engine under the crank shaft above the oil pan pasengers side. I think is 10mm nut. remove the bolt and pry it out with a flat head screw driver. push the new one in the hole as far as you can and tighten the bolt. Thighting the bolt will pull it up tight. Start your truck.
