Rear axle info - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-07-2007, 10:13 PM Thread Starter
J-ROCK's Avatar
Send a message via MSN to J-ROCK
Rear axle info
Just bought an f350, the rear 10.5 sterling needs pinion bearings at least, makes a racket. I prefer to upgrade rather then repair so I'm looking at options.. such as the stout 14 bolt rear end from a chev or a 60 from a dodge. My question is, which if either would match the ford bolt pattern.
How wide is the sterling rear, I'd measure mine but it's not delivered yet.
Any info is good info.
J-ROCK is offline
post #2 of 3 Old 08-07-2007, 11:41 PM
willypscustoms's Avatar
i would not do either you could ether build the 10.5 up with a locker and it will be stroger then the 14 bolt pos cevy rear end and stronger than dodge rear end. if you want to upgrade go to a dana 80 witch is a ford rear end thats what i did i have a dana 80 with Detroit locker. the bolt pattern on Chevy and dodge are different than fords, chevy and dodge are 8 on 8.5 fords are 8 on 170mm or something like tht. if i were you i would just get the 10.5 rebuilt with locker and all the goodies unless you can find a dana 80 for a good price.
IF CAPS ARE ON IM AT WORK I CANT TAKE THEM OFF
willypscustom cold air intake
4" exhaust straight piped
banks 6 gun
itp regulated return
dp tuner
9" lift 37" tires
agr hydro. assist steering
greddy turbo timer and greddy gauges
wicked wheel
and some other small mods
willypscustoms is offline
post #3 of 3 Old 08-08-2007, 12:00 AM Thread Starter
J-ROCK's Avatar
I don't need a locker for my tow rig, thats what the wheeler is for.. I just prefer to upgrade for my money.
J-ROCK is offline
