new to powerstroke just bought f-350
Hi guys well going through the big D and bought a replacment for my 06 dodge with a cummins yeayea i know i will prob get some greif but oh well.
So just bought a 2000 f-350 4x4 reg cab long bed with 196000 on the odo runs good but i have already had to replace the powersteering pump in the last week come to find out they are junk, so big boring question what are the top 10 things i need to look at and take care of or need to check or plan for. I have ben around the diesel community for some time and have a pretty good knowledge of dodge but dont know jack about powerstroke other than the truck puts a grin on my face !Thanks in advance. BTW i already replaced fuel filter and air filter! |
Welcome and congrats on the purchase. I am sure u will like it. No tips tho, sorry.
Welcome new guy. Why do you think you need a new PS pump? Maybe a PS fluid flush would help... Helped a ton on mine...
closing in on 200k-
Injector o-rings (probably injectors before 300k) Make sure all the clips are still intact on the airbox and all the typical stuff such as u-joints, brakes, and bearings. |
Just like the cummins, the 7.3 will take care of you if you take care of it. That said, CPS is a major known problem, HPOP(high pressure oil pump) o-rings and fitting may begin to leak. As mentioned, injector o-rings, glow plugs and relay. If you haven't already, do what others have said and check your intake, or do the DIY filter (google 6637 mod). Typical stuff really, turbo impeller, fluids, intake boots, yadda yadda yadda. Oh, if you haven't already noticed, check out your serpentine belt routing
Hi fellow newbie , I am too . I have a 2001 F250 Super duty 4x4 189,000 miles ,been a great truck, no troubles 'til today Got a P1316 code, sure hope the clips are all I need. Cool site wish I would have found it before I had this code come up, oh well I am a member now so am looking forward to all the good info here!
I only have 2 clips in air box am i missing something? btw thanks for the reply have ben looking at injector pricing as well as prices for hpop so i can budget for it! how hard is it to replace the o-rings should be same as aCAT right? 2 o-rings and brass cup?
BTW thanks for the reply |
TURNS OUT IT WASNT EVEN MY O RINGS LEAKING IT WAS MY PUMP IT WAS LEAKIN AROUND THE PLATE ON THE BACK WHERE THAT SNAP RING IS LUCKILY I FOUND A GOOD USED PUMP, BUT MY MECHANIC THAT I HAVE CHANGING MY PUMP SAID THE CHEAPEST HE CAN FIND IS 700 AND CHEAPESTI FOUND WAS 430 ON A HPOP |
