I found a PSD - Ford Powerstroke Diesel Forum
Old 08-07-2007, 09:52 AM
I found a PSD
I think I have found a truck. It is an '03 7.3 crew cab Lariat 4x4. 100k on the odometer. Runs real good. Only quwstion I have is there is a little play in the steering and I was wondering if that could mean tierod ends? I should close the deal Thursday.
Old 08-08-2007, 05:26 PM
It might just need front sway bar bushings, I had to replace mine on my 1997 F-350 and it really tightened it up. There is also an adjustment in the gearbox (steering)- not sure about 03 models though. Check with a qualified mechanic if you aren't sure about what to do.
Hope this helps, good luck.
Old 08-08-2007, 05:31 PM
if you can get it up inthe air by any chance then you can check the tie rods. I'd ask to take it to your mechanic before any decisions.
