LIFT and cutouts - Ford Powerstroke Diesel Forum
Old 06-10-2011, 07:50 AM
Question LIFT and cutouts
I HAVE 2.5 LEVELING KIT AND WONT A LITTLE MORE LIFT I WAS THINKING A 2" OR 3" HANGER KIT UP FRONT BLOCKS REAR CAN I RUN BOTH LIKE THAT to clear my 37s alittle better[
Old 06-10-2011, 08:54 AM
Personally I would skip the hanger kits and get a quality 4" or 6" lift kit... likely to get better ride quality, and have a system made to work together to lift the truck.
Old 06-10-2011, 09:12 AM
Feedback Score: 7 reviews
that is something i can not condone. (that large anyway)
Old 06-10-2011, 10:13 AM
Feedback Score: 5 reviews
2-3" hanger kits but you will need a drop Pitman arm, drop track bar bracket and longer sway bar links..we have all.
Old 06-10-2011, 12:03 PM
wait-you want to AD an additional 3" hanger lift to a 2.5" leveling kit? WITHOUT a drop trak bar bracket, pitman arm, or sway bar links? You should do the links and bracket with just a leveling kit, a 5" lift without them would be ludacris. Bumpsteer, death wobble, the axle would be sticking out one side at least 3", and the shackles would be rubbing the frame.
and, if you re-used your stock shocks with the leveling kit, they will certainly not accomodate another 3".
Basically, you need to rework your entire suspension. At that point, you might as well get a quality 6" lift and not mixmatch parts never designed to work together.
Old 06-10-2011, 12:47 PM
NO .. im going to do drop trak bar bracket, pitman arm, or sway bar links i was just wonting to know if a hanger kit added to my 2.5 leveling kit would be a good or bad idea
Old 06-10-2011, 12:48 PM
Personally, I'd get a set of deaver front springs and enjoy a truck that rode like a cadillac.
If you're doing it on a budget, why not.
Old 06-10-2011, 12:52 PM
You really need a 1" adjustable trac bar, not a drop bracket for the stock 3/4"...
Old 06-10-2011, 12:54 PM
He really needs both-lol-with just an adjustable track bar and not a drop bracket his drag link and trak bar will not be close to parallel. BUMP STEER!
Old 06-10-2011, 12:55 PM
I gave the OP what was needed..to add to his kit..plus longer shocks..
Tags
lift 37s
