Suspension Question - Ford Powerstroke Diesel Forum
Old 06-08-2011, 06:54 PM
Suspension Question
so a friend of mine has an early 99 and he says he has F450 front springs and F350 rear springs....is that similar to "X" code springs? i was thinking about doing the same thing to my truck. or maybe just F350 front springs with F350 rears. i now have a 6 in lift on my truck, but can i just bolt the 350 or 450 leaf springs up? i know i will need a different block in the rear and a pitman arm. but what else is needed?
Old 06-08-2011, 07:53 PM
Feedback Score: 5 reviews
X-Codes are 6,000lb springs...
I'm pretty sure the 450 springs are 5,600lb springs.... but I may be wrong. I would htink they would work, as long as you can adjust your track bar. Keep in mind I am guessing.
Old 06-08-2011, 07:57 PM
i will have to take at his truck in better detail and see what all i need. next question is where can i find the X code springs besides the dealership?
Old 06-08-2011, 08:13 PM
Umm...
I found mine in a junk yard using a link Buffalo444 gave me, http://www.car-part.com/
Question about plowing snow
I paid about $160ish for both X-code sorings...if I remember right.... could be wrong tho. I still need to install them.
Old 06-09-2011, 09:14 AM
Codes..look at the door sticker, with X codes you should get longer shocks and a adj track bar to recenter the axle. Thats it.
