can someone tell me Y "exactly" - Ford Powerstroke Diesel Forum
Old 06-07-2011, 08:07 PM
can someone tell me why my waste gate openes at 15psi. and i am trying to stay away from a programer... so far i am extreamly impressed with this truck ....
can i just change the waste gate to get it to stay closed longer?
and if i unhook that vacuum hose to it what will happen?
Old 06-07-2011, 08:46 PM
I unhooked the waste gate hose on my truck a few times. The problem is that on the top end, the turbo doesnt like it. I had some bad fluttering sounds out of mine. And thats with the Wicked Wheel. I have also used a manual boost controler on my truck and thats much better than unplugging the waste gate.
Old 06-08-2011, 12:11 PM
Are you sure it's opening? If you don't have a chip it is very possible it can only build 15 psi anyways... especially if you had a very small leak somewhere that could drop 1-2 psi.
I bet if you had a chip you would build 20-25 without it opening... I know I can. It flutters though, gonna have to get a WW.
Old 06-08-2011, 01:21 PM
what setting are you running your programer at , tow haul , or full race to get 20 + boost???
i have a wicked wheel, fully rebuilt turbo, removed intake air heater, removed that cold weather flap on exhaust side of turbo., 140 IDM, high pressure crossover line, gauges, Muffler is removed and its straightpipe, DIY intake,..
this thing is wide open no restrictions.....
Old 06-09-2011, 06:32 PM
??? just wondering if anyone else could answer this with some backround
Old 06-10-2011, 08:57 AM
I hit 25-26 psi on the 80 econo tune with my yellow truck, straight pipe, DIY intake, unpluged wastegate... not hard to do eather.
Old 06-10-2011, 10:41 AM
The wastegate is mechanical. It should only be opening when it receives enough pressure to push the rod to open it. Assuming it is in proper working order. When you unhook the red line in theory it should never open because it will never get enough pressure from the atmosphere to push it open. On a stock truck you may just not be getting the fuel to push that much boost. Or you could very well have a leak somewhere including your up-pipes which will limit your boost as well since all the exhaust gas isn't spinning the turbine.
Old 06-10-2011, 11:42 PM
WW drops a few pounds of boost so I'm told. I can hit 20+ on any of my settings but stock. Stock is probably around like 17-18 if I stay on it for a while.
