no brake lights,turn signals, or hazards
Hopefully yall can help me out because I really dont want to take my truck to the shop. My brake lights, turn signals, and hazards dont work, also idk if this is related but my high beams dont work either. I have checked the multi function switch (if im correct it's the one connected to the blinker/wiper lever on the left side),replaced the bulbs, and checked all of the fuses under the dash. Some people have said it may be the sensor behind the brake pedal, but would that cause my blinkers to not work also?
Any helpwould be great. Thanks |
Sounds like the multi function switch, sometimes they go out and the wires that go thru the steering column are short and when you tilt the steering wheel the will pull out. Take the bottom of your steering column off and check to make sure the wires did`nt pull back out. Check to see if the wires are burned also.
Peace out |
