tranny temp - Ford Powerstroke Diesel Forum
Old 08-06-2007, 05:19 PM
tranny temp
what is normal temp? My tranny has been creeping up there around 180, never seen it get that high before. How much will it go up if I am towing something?
Old 08-06-2007, 05:23 PM
Beer Drinker/Ballast Guy
That's a good question...I'd like to know as well so here's a bump. Mine's sitting around 190 on long trips.
Old 08-06-2007, 05:29 PM
ROYAL Purple and Filter change and maybe a shift kit upgrade!
Old 08-06-2007, 05:36 PM
180 is optimal operating temp.200- 210 is running hot and 220 and beyond is redline shuter down. go check your tranny cooler and straiten out the fins on it and make sure nothing is blockin air flow to it
Old 08-06-2007, 06:58 PM
Almostdunfukinwidit
about 90 degrees above ambient temps is normal 225 or higher back off 240 for long you might have cooked the fluid
Old 08-06-2007, 07:37 PM
Your tranny temp should be about double of the outside temp. So if it's 100 out you should see between 190-200 degrees. Just a good rule of thumb
Old 08-06-2007, 10:08 PM
Well I guess mine is too cool if there is such a thing, since I added the aux cooler it runs about 130-150. Is that a bad thing?
Old 08-07-2007, 02:38 AM
Almostdunfukinwidit
NO not a bad thing at all that will keep it nice an cool when towing. some days mine doesnt get over 150 either
