oasis report done - Ford Powerstroke Diesel Forum
post #1 of 1 Old 08-06-2007, 02:29 PM Thread Starter
oasis report done
Well I just got my oasis report for a truck i have been looking at. It is a 2002 f350 crew cab 4x4 with a 7.3 diesel it has 89,000 miles and the dealership is asking $24,000. Here is the report I think it looks pretty good except the tranny slips but i would like to know what every one else thinks.
Standard Claims List For Model Year 2002
Detailed Vehicle Specification
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTSW31F62EB05837 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 29-OCT-2001 10-NOV-2001 148072 USA 3 2E06 030008 F6TZ 9F838 A D21 42 4100
AWS Claim Key: 556742 Trx Code: 2 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 02746 - * Name: ROMEO FORD INC Ph: 586-7525500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2002 Doc #:02488201
Cust Comments: INSPECT FOR VEHICLE STALLS WHEN ACCELERATE FROM STOP
Tech Comments: PERFROM DIESEL DIAGNOSIS PERFORMANCE SHEET PASS CODES PRESEN T REPLACE ICP & IPR
1FTSW31F62EB05837 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 29-OCT-2001 10-NOV-2001 148072 USA 15 7T03 060901 F85Z 2L373 AB H19 42 24956
AWS Claim Key: 4115456 Trx Code: E83 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 03025 - * Name: JEROME-DUNCAN, INC. Ph: 586-2687500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:08-JAN-2003 Doc #:16487901
Cust Comments: ABS WARNING LIGHT COMES ON AFTER DRIVING A COUPLE OF MILE CK AND ADV
Tech Comments: BPN 2B373, CCC H19, CC 42 ROAD TEST VERFIY ABS LIGHT ON NGS EC TEST C1229 VIEW ABS PID PER PINPIONT TEST REAR ABS SENSOR AT 0MPH PPT TO ABS SENSOR REMOVE AND REPLACE CLEAR CODE
1FTSW31F62EB05837 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 29-OCT-2001 10-NOV-2001 148072 USA 15 7N02 010505 1L2Z 14529 BA G07 42 24956
AWS Claim Key: 4115455 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03025 - * Name: JEROME-DUNCAN, INC. Ph: 586-2687500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:08-JAN-2003 Doc #:16487902
Cust Comments: DRIVERS POWER WINDOW GOES DOWN BUT DOES NOT GO UP. CK AND ADV
Tech Comments: BPN 14529, CCC G07, CC 42 VERIFY WINDOW INOP IN THE UP POSTION DIAG TO SWICTH REMOVE AND REPLACE AND RETEST
1FTSW31F62EB05837 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 29-OCT-2001 10-NOV-2001 148072 USA 15 2H01 030008 F81Z 6C640 CA L65 D8 24956
AWS Claim Key: 4115454 Trx Code: E84 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 03025 - * Name: JEROME-DUNCAN, INC. Ph: 586-2687500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:08-JAN-2003 Doc #:16487904
Cust Comments: CUSTOMER STATES ENGINE OIL LEAK FROM FRONT OF ENGINE. CK AND ADV
Tech Comments: CCC L65, CC D8, BPN 6C640 VERIFY OIL LEAK AND DYE TEST FOUND LEAKS AT BOTH INTERCOOLER PIPES AND INTAKE MANIFOLD TUBE REMOVE INTAKE MANIFOLD REPALCE ORANGE BOOTS TUBES REINSTALL REMOVE AND REPLACE INTERCOOLER PIPES CLEAN AND RETEST NO FAULTS
1FTSW31F62EB05837 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 29-OCT-2001 10-NOV-2001 148072 USA 26 3A04 070100 F81Z 7G422 AA P67 42 33267
AWS Claim Key: 8320640 Trx Code: E84 Labor Hrs: 12.5
Dlr Cd-Sub Cd: 03025 - * Name: JEROME-DUNCAN, INC. Ph: 586-2687500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-2003 Doc #:20958401
Cust Comments: CHECK TRANS OPERATION SLIPS ON 1 2 SHIFT
Tech Comments: 7G422 P67 42 RD TEST,VRFY DLYD AND SLPPNG ON 2 3 SHFT,EEC TST NO CDS,PRESS TST D75PSI,R100PSI,NO FLTS.RMV PAN AND ACCMLTR BDY,FND 3 GEAR ACCMLTR VLV STCKNG,ALSO FND HVY CLTCH MTRL IN PAN REM TRANS MT TO BNCH,TRDWN,FND OD 2,3 GR CLTCHS BRNT,OVRHL TRNS,CLN AND OVRHL VLV BDY,FLSH CLR,ALSO INSTL NEW CNVRTR FND A HEAT RING ON FACE OF CNVRTR INSTALL,RD TEST NO FLTS
1FTSW31F62EB05837 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 29-OCT-2001 10-NOV-2001 148072 USA 26 5T01 * * * * * * 33267
AWS Claim Key: 8320639 Trx Code: 03B03 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03025 - * Name: JEROME-DUNCAN, INC. Ph: 586-2687500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-2003 Doc #:20958402
Cust Comments: PERFORM RECALL 03B03 ACCEL PEDAL SENSOR CUSTOMER STATES NO THROTTLE RESPONSE
Tech Comments: 03B03B INSTALL TROTTLE PEADEL ASSEMBY PER RECALL
1FTSW31F62EB05837 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 29-OCT-2001 10-NOV-2001 148072 USA 30 2B01 0300XX F7TZ 12K073 A D21 42 35384
AWS Claim Key: 9819945 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 02685 - * Name: FRED GRANDE FORD SLS, INC Ph: 586-7273415 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2004 Doc #:113863A
Cust Comments: THE ENGINE STALLS AND WILL NOT RESTART UNTIL IT COOLS
Tech Comments: PERFORM DIAGNOSTICS AND PINPOINT TEST PER PC ED AND REPLACED THE CAMSHAFT SENSOR AND RETEST.
1FTSW31F62EB05837 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 29-OCT-2001 10-NOV-2001 148072 USA 30 5B04 050306 1C3Z 3B396 CB P82 41 35384
AWS Claim Key: 9819946 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02685 - * Name: FRED GRANDE FORD SLS, INC Ph: 586-7273415 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2004 Doc #:113863B
Cust Comments: THE FRONT LOCKING HUBS TURN VERY HARD
Tech Comments: REPLACED THE FRONT LOCKING HUBS
1FTSW31F62EB05837 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 29-OCT-2001 10-NOV-2001 148072 USA 30 2I04 NANANA F81Z 12B533 AC D03 42 35710
AWS Claim Key: 9870531 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 03025 - * Name: JEROME-DUNCAN, INC. Ph: 586-2687500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:22-APR-2004 Doc #:22969801
Cust Comments: CUSTOMER STATES VEHICLE HARD TO START ON COLD STARTS. CK AND ADV
Tech Comments: 42 12B533 D03 EEC TEST NO CODES PERFORM GLOW PLUG TEST WITH NGE FAILED PINPIONT TEST TO GLOW PLUG RELAY R AND R RELAY AND RETEST
1FTSW31F62EB05837 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 29-OCT-2001 10-NOV-2001 148072 USA 50 1H03 030804 4C3Z 9J460 A D21 42 62035
AWS Claim Key: 14755793 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 02685 - * Name: FRED GRANDE FORD SLS, INC Ph: 586-7273415 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:15-DEC-2005 Doc #:119090A
Cust Comments: STALLS WHEN DRIVING STARTS BACK UP THEN QUITS
Tech Comments: VERIFIED CONCERN PERFORMED EEC TEST BALANCE TEST IGNITION TEST R&R DPFE SENSOR RETESTED OK
1FTSW31F62EB05837 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 29-OCT-2001 10-NOV-2001 148072 USA 53 2E06 100106 F81Z 9C407 AC D02 63 65817
AWS Claim Key: 15132211 Trx Code: E72 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 02746 - * Name: ROMEO FORD INC Ph: 586-7525500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:01-MAR-2006 Doc #:05695702
Cust Comments: CRANK NO START COLD
Tech Comments: VERIFIED CONCERN PERFORM HARD START DIAGNOSIS SHEET AND PINPOINT CONCERN TO GLOW PLUGS. INSPECT RELAY AND FOUND NO VOLTAGE. REMOVE AND REPLACE RELAY. VERIFIED GLOW PLUGS OK VEHICLE STILL NOT STARTING. PERFORM THE REMAINING DIAGNOSIS SHEET AND FOUND NO FUEL PRESSURE. INSPECT AND FOUND POWER TO THE FUEL PUMP, REMOVED FUEL PUMP AND FOUND IT TO BE INOP ERATIVE. REMOVED BROKEN RUSTED BOLTS AND REPLA
2006 Ford F250 crew cab FX4 6.0 PSD
Boss V-plow Whelen 90 strobes
33x12.5R17 mickey thompson mtz
17x9 eagle alloy wheels
bd414 is offline
