a/c not working right - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-03-2011, 07:38 PM Thread Starter
reed1320's Avatar
I have a 2002 f350 I have put some cans of freon in it but it will blow cold air when I have it in max ac and the blower on high but when I change it to regular ac or the turn the blower down it will work for a for 2 min then it blows warm so I turn it for about 5 min then turn back on to max ac and the blower on high and it stays cold the rest of the time any help will be appreciated thanks
reed1320 is offline
post #2 of 8 Old 06-03-2011, 08:24 PM
dazdillenger's Avatar
Feedback Score: 7 reviews
are you moving when this happens? The condensor can get heat soaked and not blow cold until you are driving again. Did you check the freon pressure?
dazdillenger is offline
post #3 of 8 Old 06-04-2011, 05:51 AM Thread Starter
reed1320's Avatar
I'm driving when it happen and I check the pressure with the gauge that comes with the can I buy at auto part store , it was low but it blows cold air sometime and if the freon is low would it always blow warm air and never cold .
reed1320 is offline
post #4 of 8 Old 06-04-2011, 12:00 PM
kitchene's Avatar
My ac blows cold for like 2 minutes when I first start the truck then won't work again till I restart the truck. It's annoying.
Kitchene
1997 F350 SRW CCLB 4x4 XLT 7.3, ZF5, bone stock but not for long.
2000 F550 2WD CC Cab/Chassis PSD (in progress)
DIY Intake with AEM dry cone filter, ZooDad, AIH Delete, Foil Removed, Superchips Flashpaq, Mobile Delvac.
1988 F800 toy... Dozer hauler.. for sale.. 7.8L inline 6, 6sp Trans, 2sp diff
kitchene is offline
post #5 of 8 Old 06-04-2011, 03:14 PM Thread Starter
reed1320's Avatar
Yep mine is annoying but atleast I get ac but full blast the hole time but its better then nothin cause I work out of ny truck I don't want pay to put it in the shop so I will look around the internet and try to find a solution
reed1320 is offline
post #6 of 8 Old 06-04-2011, 03:16 PM
The way you check pressure is with the ac set to max, with the compressor engaged. If the pressure slowly goes down until the compressor kicks off, then back up until compressor comes back on, you are low on coolant. When the AC is blowing hot have you pulled over to check to make sure the compressor is engaged?
2005 Lariat CCSB F-350 SRW
300,000 miles and going strong
Exterior
12" fabtech lift with 40" Xterrain's on M/T classic locks, Adjustable track bar, Bilstein 7100 reservoir shocks
Performance
Edge juice/attitude CTS, SCT with ID tunes, Snow meth. injection, Diamond eye 4" exhaust, 03 turbo, ARP studs, Sinister coolant filter
Interior
2010 stone seats/console, pioneer avic d3 with backup camera/bluetooth
Misc.
Viair 450c compressor, dual 2.5 gallon tanks, air horns rated @115db
post #7 of 8 Old 06-04-2011, 03:17 PM
Eric's Avatar
Feedback Score: 6 reviews
Check the clutch. Mine will disengage and won't kick back in unless I smack it with a screw driver. It will stay working if I leave it wide open. I've been told that you can take a shim out of it but I haven't checked yet
Early 99 F250 with a bunch of extra junk...
Eric is offline
post #8 of 8 Old 06-05-2011, 09:43 AM Thread Starter
reed1320's Avatar
It started to blow warm so I pulled over and the ac was not engaged I will try the wack with a screw driver next time
reed1320 is offline
