Vibration over 70 mph
OK, truck is vibrating around 70 and gets more aggressive as I speed up. Its not that bad but it is kind of annoying and getting worse. There is no correlation with the vibration and RPMs. I was wondering if anyone has had a vibration similar to this and if so what was the cause... Tires, U-Joints, rear end, drive-shaft, etc??
I have a pretty good leak from the the front of the differential so obviously the pinion seal is shot.. Could that cause a vibe to move up the drive-shaft and shake the truck? |
Lets start with the basics... whens the last time you rotated and balanced your tires? How old are the ball joints?
You wouldn't happen to have Nitto Terra Grapplers, would you?
I have similar issues. When it first started, I had the tires balanced and rotated, which did not correct the problem. So after further investigation, I determined that my issue is cause by a bad carrier bearing.
I have BF Goodrich Mud-Terrains. I balance and rotate them every oil change (3000-4000mi.)
All the U-Joints and the carrier bearings are about 3 years old with about 30,000 miles on them. I inspect them regularly and they seem to be in good shape except for the rear one is showing some wear.. |
