Boost gauge question?
OK,
I installed my gauges, and after a few wiring "issues" everything is working like it should. Except my boost gauge doesn't drop below 6* when the power to it is off. It never goes below 6*. What's wrong, anybody know?? It stops and rests at 6*, like that is 0 or something. Thanks for any help guys! chris |
Well, I just took it for a ride. Still never went below 6.
I think all of the readings were about 6 lbs. too high. I even got it pinned at 35 lbs. for a split second. There's no way, with my current mods, and a stock turbo that I'll get near 35 lbs. What is going on? It's t'd into the map line. That was the only gauge I didn't have hooked up last night when I took the truck out after installing the gauges, because I didn't have the 1/4" T and the 1/4" barbs I needed. So I rode around for a while with other end of the boost line just hanging out under the hood, not hooked up to anything. Could that be part of the problem?? I need help. thanks chris |
I don't think that would've done anything. I'd take the guage back, there has to be something wrong with it.
You have a bad guage... the pyro is electric powered the boost has olny a line 2 it and what electric there is powers hte lite...... Bill
I called the guy I bought it from today, he thinks that it maybe didn't get calibrated right, so he is sending me another one at no charge.
Hopefully that does the trick!! chris |
Quick update:
Got the new gauge in yesterday, replaced it, and everythging is working great. Somewhere around 25-28PSI max boost. Thanks for the replies guys! |
