need help, pulling standard trans clutch - Ford Powerstroke Diesel Forum
Old 05-23-2011, 10:48 AM
How do i get the hydraulic part of the clutch out of the bell housing? I am pulling a 5 speed. Can i do it with out taking off a line keeping the system in tact? I only have one bolt left in the bell housing but need to get the line off the bellhousing so i can pull trans back?
thx
Old 05-23-2011, 10:50 AM
the clutch line?
There should be a bleeder on it, id just remove it and bleed the system after, ive never taken a 5 speed from a P-stroke before only autos but im sure its the same as anything else..
Old 05-23-2011, 10:52 AM
the line has to be removed or the cylinder intact. Its part of thre bellhousing and I casn not pull trans out til thats off
Old 05-23-2011, 10:53 AM
yes but on that line there should be a bleeder screw, there has to be a way to get the air out of the system when removed, id just remove the line and bleed it after.
Old 05-23-2011, 10:55 AM
right, but i am asking how to remove the line?
Old 05-23-2011, 11:00 AM
is there not a screw type fitting into the slave? or is it part of the slave, if you take a pic for me id be able to tell you..
Old 05-23-2011, 01:21 PM
simply twist the slave cylinder to the left and it loosens with 1/3 of a turn,..then pull straight out,.. you can just tie it back out of your way,... no fluid loss,.. just dont lose the rod fron the end
Old 05-23-2011, 02:01 PM
ah see! perfect ^
Ive never messed with manuals..lol
Old 05-23-2011, 03:00 PM
thx got it......
