standard trans stuck in gear! Help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-22-2011, 03:04 PM Thread Starter
A friends f350 with a standard is stuck in gear. Either 1st or 3rd cant tell. He had it towed to me. I just pulled the sghifter off but dont see much. Any help? I have had this happen with hot rod 4 speeds when then get stuck in 2 gears at the same time when the shifter malfunctioned. I had to manually move one of the levers then it worked again. Any help appreciated
2008 6.4 f250 lariat 4wd
melmount is offline
post #2 of 4 Old 05-22-2011, 03:10 PM
usnavyad's Avatar
Feedback Score: 3 reviews
how do the shift forks look
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #3 of 4 Old 05-22-2011, 03:32 PM Thread Starter
the shifter is a top loader. How do i get to the forks? All i did was pull the shifter out the top? Its got a ball on the end of the shifting part. Not sure what I am looking for
melmount is offline
post #4 of 4 Old 05-22-2011, 04:22 PM Thread Starter
bump... this happen to anyone?
melmount is offline
