Coolant Swap - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-20-2011, 05:10 PM Thread Starter
Coolant Swap
Hello, I have a 02 7.3cc 4x4 with 61k. My question is what coolant to put back in after i drain it. The coolant in the tank is almost clear looking and original. What's the best way to flush and how much coolant does it hold. I had the tranny serviced at the ford garage at 58k. This thing has gotta out last me, if there is anything else the needs a good going over feel free to throw that in too. I recently put a 4" turbo back magnaflow on and did the DIY intake with a donaldson filter. The tunes come from a edge evo running in middle program(80hp race i think). Truck is in excellent shape in every way. I also run rotella T standard oil and was thinking about switching to synthetic oil maybe the rotella brand. Does synthetic change anything with the HPOP and injectors? I really need to try to boost MPG's, that's the only down side to the truck. Thanks is advance for the info and like i said throw in any other info that could be useful. Thanks
LoneWolfe is offline
post #2 of 7 Old 05-20-2011, 09:57 PM
Flush it out completely and put in CAT/Fleetrite/Rotella/etc.. EC1 Rated ELC coolant.. best for our motors.. btw if you dont have a coolant filter get one asap.
Dietoremain is offline
post #3 of 7 Old 05-21-2011, 06:23 AM
Here is a good site that tells all the options for 7.3 coolant, He is a master diesel tech for Ford, a great site for other information too, he also answers questions and is a really cool guy.
dieselmann's Page
pablito is offline
post #4 of 7 Old 05-21-2011, 04:48 PM Thread Starter
Thanks for the replies
post #5 of 7 Old 05-21-2011, 09:43 PM
ScottyP5947's Avatar
Quoted: 2 Post(s)
X2 on the EC1 Rated ELC coolant and the coolant filter. I have replaced two water pumps (101,000 and 135,000) on my truck because I didn't opt for the coolant filter right away...
As for running 5-40 rotella, go for it! I won't try and sell you on a huge mpg increase, but there is a slight one. The truck will run smoother, start faster and easier in the cold... well worth the extra bucks. Do 5k change intervals and it isn't so bad in cost.
Other than that, the best way to get better MPG is to adjust the nut behind the steering wheel. Keep it under 2k rpm and coast a lot, drive conservatively.
Scott
2000 XLT F-250 7.3 Crew Cab Auto w/Transgo shift kit
Zoodad
4" MBRP turbo back exhaust w/muffler
PHP TS chip - 65 tow/80DD/120 race
Stancor relay
Caterpillar ELC coolant
Broken-into door lock mod
6637 filter
285/75/16 Hankook ATM's
2" Rough Country add a leafs all around
In the Driveway:
2000
, chipped! (For the wife)
1995 Ford Mustang 3.8 (
2012 Dodge CCSB 2500 w/Hemi
ScottyP5947 is offline
post #6 of 7 Old 05-21-2011, 09:45 PM
Quoted: 2 Post(s)
Oh yeah, and normally driving on the hottest tune you have but driving like gramps will get you the best MPG. I simply can't resist punching it when I am running a hotter tune, so this option isn't for everyone.
Scott
Zoodad
Stancor relay
6637 filter
In the Driveway:
2000
post #7 of 7 Old 05-21-2011, 10:30 PM
Scott
my php 120 extreme tune actually drives real nice even when you're goin on it easy.. ive learned to be balanced with my 'foot to the floor' moments..haha.
