the door ajar light - Ford Powerstroke Diesel Forum
Old 05-18-2011, 05:25 PM
the door ajar light
the door ajar light wont come off. the third brake light light stays on after you open the door and it over a long period of time it goes off. someone said the switch is in the door latch?! if i adjust the striker would that help? i gotta get that light and dash light ajar light out its an 03 or 04 super duty
Old 05-18-2011, 05:37 PM
duct tape & zip ties
Take Brake cleaner to all the latches. Just spray them down real good. Then follow up with a dry lubricant. The problem is dirt build up on the latch will not allow the latch to ground out.
There is many threads about this on the site.
Old 05-19-2011, 01:31 PM
what if i took the pressure washer with heat on it think that would help? or too much..thats a good idea. and if that doesnt work its safe to say the latch could be bad? is there a sensor for that in the latch itsself?
Old 05-19-2011, 01:34 PM
Mine is on because my security module is f'ed up. Ford wanted like $600 for a new one, so I just deal with the light... Although everything else works just fine, just the stupid light. But it seems most people around here have problems with the latch.
Old 05-19-2011, 03:39 PM
Clean them one at a time and see if the light goes off on the dash. If it does then you found the one that was causing the problem.
Old 05-20-2011, 04:05 AM
My driver rear door does that. well it's always off actually. Once my boss borrowed my truck and then my int light wouldn't turn off like yours so I degreased/powerwashed the door jambs and then sprayed a bunch of fluid film in the latches (then slammed the doors a bunch of times to work it in there)
I just did that to a friends ranger the other day too lol
Old 05-22-2011, 02:48 PM
aLRIGHT ill give it a try
