Sputtering sound? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-18-2011, 06:02 PM Thread Starter
Sputtering sound?
I was driving with my edge programer on 100 hp setting and I was pullin a hill and noticed when I stood on it my turbo I think sputtered. Almost sounded like a blow off valve. It did it once but it made the sputter sound three or four times the one time it did it. Any thoughts?
2000 F250 SD ex cab long bed
6spd trans
south bend 350hp-750lb/ft clutch
6 in lift with 37in Km2 BFG
4in mbrp turbo back single exhaust
TS 6 Pos Chip
DIY intake
SOON TO COME
new injectors
some sort of turbo upgrade
Sullie250 is offline
post #2 of 10 Old 05-18-2011, 09:32 PM
444 ci's Avatar
sounds like your stock hpop cant keep up with the demand from your injectors.
444 ci is offline
post #3 of 10 Old 05-18-2011, 10:24 PM Thread Starter
would it even do that with stock injectors?
6spd trans
TS 6 Pos Chip
DIY intake
SOON TO COME
new injectors
post #4 of 10 Old 05-19-2011, 07:08 AM
Like all comman turbo sputter questions is do you have turbo surge. Are you still running the stock compressor wheel? My 2000 was doing the same thing, then I installed Beans Diesels compressor wheel and no more surge. It spools faster too.
EArmsF350 is offline
post #5 of 10 Old 05-19-2011, 09:10 AM Thread Starter
that was the first time it ever did it. well that i noticed it at least. what exactly is "turbo surge"?
6spd trans
TS 6 Pos Chip
DIY intake
SOON TO COME
new injectors
post #6 of 10 Old 05-19-2011, 09:37 AM Thread Starter
googled turbo surge and found a old video on here....thats what mine is doin. would a whicked wheel fix this?
6spd trans
TS 6 Pos Chip
DIY intake
SOON TO COME
new injectors
post #7 of 10 Old 05-19-2011, 11:17 AM
yup usually cures 99% of it. and sounds better too!
Dietoremain is offline
post #8 of 10 Old 05-22-2011, 07:01 PM
Sorry I havent gotten back to you but yes if you googled it and found that to be your issue then you know what you have to do. There are many after market compressor wheels on the market. I used Beans Diesel Performance compressor wheel just becauseI do alot of business with them. Alot of guys talk about the Wicked Wheel and it too works well. Be sure to check your up pipe gaskets and replace if needed if your into the turbo. Most who replace the compressor wheel just split the turbo housing to replace it but if you have up pipes leaking, good time to do all. You have to have a good seal on your up pipes to get full and efficieant spool on your turbo. Good luck man.
post #9 of 10 Old 05-22-2011, 11:39 PM Thread Starter
is there much difference in which brand i go with? is it easier to pull the turbo off and replace all seals while i am in there as well as a ebpv delete pedestal on it too? would that help with more air flow?
6spd trans
TS 6 Pos Chip
DIY intake
SOON TO COME
new injectors
post #10 of 10 Old 05-23-2011, 03:15 PM
03_Turbo7.3's Avatar
Why would you use google when the resources are all here.
Turbo shudder/surge...why and fix.. ( write up )
The surge fix is the WW, which is an earlier compressor wheel we can put in our trucks, its a little louder and in total you can lose 1-2psi by installing it, but it does usually cure surge, another route is the ATS housing. have a read at the write up i did, youll enjoy it.
05+ coils, 10 Rear diff, box, tailgate, lights, bumper, Full 07 front harley swap...the list is endless.
AS IM RARLEY on here anymore...have a question ?? EMAIL ME
gladly answer any of your questions. OR search me on facebook. ill help out anyway I can !
updated as of OCT 28/2013
03_Turbo7.3 is offline
