Torque Converter Installation??? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-18-2011, 02:48 AM Thread Starter
82racin's Avatar
Hey guys I'm gonna be swapping torque converters. I bascially know how to do it . But just wanting a step by step guide on how to do it on these trucks. When I read a how-to it makes the job so much easier Is there anything I should take extra care on or any tips to make it easier?
82racin is offline
post #2 of 11 Old 05-18-2011, 03:01 AM
BIGBILL105 45's Avatar
Just make sure it locks into the tranny.
PM ME FOR VINYL DECALS!
SOLD!!!!!
ARP head studs
4 inch down pipe
5 inch straight pipe
ts 6 pos chip
foil delete w/ polished IC pipes
ugly step delete
2% tint
black lariat rims
35 inch Pro Comp Xterrains
7 inch in dash dvd player
remote starter
16.265
BIGBILL105 45 is offline
post #3 of 11 Old 05-18-2011, 06:54 AM
ridiculously_necessary's Avatar
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #4 of 11 Old 05-18-2011, 12:36 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Put some fluid in the converter, keep pushing on the converter as you spin it slowly..make SURE is all the way in! If you can't push the trans flush to the engine take it out and check the converter again..never use the bolts to pull the trans to the engine.
CT Performance, Inc. is offline
post #5 of 11 Old 05-18-2011, 07:46 PM Thread Starter
82racin's Avatar
Thanks guys, should be lots of fun !
82racin is offline
post #6 of 11 Old 05-18-2011, 08:27 PM
ScottyP5947's Avatar
Let us know how it goes, are you renting a trans jack or just using a floor jack?
Scott
2000 XLT F-250 7.3 Crew Cab Auto w/Transgo shift kit
Zoodad
4" MBRP turbo back exhaust w/muffler
PHP TS chip - 65 tow/80DD/120 race
Stancor relay
Caterpillar ELC coolant
Broken-into door lock mod
6637 filter
285/75/16 Hankook ATM's
2" Rough Country add a leafs all around
In the Driveway:
2000
, chipped! (For the wife)
1995 Ford Mustang 3.8 (
2012 Dodge CCSB 2500 w/Hemi
ScottyP5947 is offline
post #7 of 11 Old 05-18-2011, 08:33 PM Thread Starter
82racin's Avatar
ah I Don't know yet about the jack......I didn't know u could rent them where can u do that Advance auto?
82racin is offline
post #8 of 11 Old 05-18-2011, 08:34 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
How hard is it to lock the tc into the trans?
Sent from my life controlling iPhone
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #9 of 11 Old 11-29-2014, 02:28 PM
What happens when you force the TR to the block with the bolts?
I pulled my entire engine this weekend, TC came out a little ways with it ( because I made a very, VERY foolish mistake). I didn't read up at all about torque converter or anything because I was concerned about the engine not the Trans. Now here I am with the new engine in, torque converter is reattached to flywheel, bell housing bolted up but I can't spin my flywheel manually. And Do not know how to proceed.
Any thoughts?
kidsinthehall is offline
post #10 of 11 Old 11-29-2014, 02:36 PM
Quoted: 3 Post(s)
Converter first gets correctly seated in the trans then trans gets bolted to the motor then converter get bolted to the flywheel.
You HAVE to seat the converter first turning it while pushing in the converter so it mates to the splines in the front pump, it can lock in many times and go into the pump farther ea time so keep spinning it and pushing in till your sure its seated.
If you didn't do this first but bolted the trans up to the motor likely you destroyed the front pump.
The Following User Says Thank You to CT Performance, Inc. For This Useful Post:
kidsinthehall (11-29-2014)
