oil report - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-03-2007, 05:12 PM Thread Starter
strokermann's Avatar
oil report
this is what the report said. this was oil that i put in when i bought the truck in october of last year. my coolant levels have not changed at all. curious how it is getting in there.
JASON: Aluminum, chrome and iron, from the pistons, rings and cylinders, read a bit high after a
4366-mile oil run. Universal averages for typical wear are based on 5232-miles of oil use and the
presence of potassium and sodium in the oil points to some anti-freeze possibly getting into it and
causing the higher wear. 0.5% of the sample was fuel but that wouldn't be a factor in the wear. Air and
oil filtration (see silicon and insolubles) were normal. We suggest monitoring your coolant level and
stick with ~4000-mile oil changes for now. The TBN was 10.0, loads of active additive.
CB Radio- General Lee
7.3l 99 f-250 SD
4 INCH TURBO BACK TO 6 INCH MITER CUT STACKS CURIOSTY OF GRAND ROCK AND COWBOY DIESEL PERFORMANCE.
TS 6 POSTION CHIP. stock,high idle,50,75,100,140hp.
strokermann is offline
post #2 of 11 Old 08-03-2007, 05:28 PM
rankroddin250's Avatar
my Q is how did you only put 4000k on your truck since last october LOL
you might just change the oil and see what your next oil report says... coulda been a fluke ?
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #3 of 11 Old 08-03-2007, 05:51 PM Thread Starter
i only drive 2 miles 1 way to work and i don't drive it that much anyway. my wife said its to loud for teh baby to be in so we take her truck. be when i drive it. its either babied or driven like i stole it. depends on what kinda of mood i am in. and how many people my ride my tail. and no pulling at all.
7.3l 99 f-250 SD
post #4 of 11 Old 08-03-2007, 10:21 PM
Can you post the actual report? I can probably help with some of what your seeing. I can already tell you that your insolubles and fuel dillution are high due to short trip driving. Short trips are very bad on oil and all engines. The TBN is still very good. What oil were you running, and what was run b4 you bought the truck? all of this affects the oil sample
Did you inform blackstone of your short trips? How was the oil changed? if it wasn't driven for long distance b4 the change all numbers are affected
Shawn
Performance Oil Products is offline
post #5 of 11 Old 08-04-2007, 07:23 AM Thread Starter
i don't know how to post those whole report they sent a pdf file. and i was running rotella 15/40 and i did tell black stone of teh short trips. and tehfirst thing i did when i bought the truck was to change the oil. and teh owner before said he only used it i the winter to plow snow and teh ocasnial towing of a gooseneck. let me know how to post teh pdf file and iw ill. thanks
7.3l 99 f-250 SD
post #6 of 11 Old 08-04-2007, 07:27 AM Thread Starter
ok i figured it out. i just prinedt it and scaned it and svaed it to my photobucket so here it is
oilreport.jpg - Image - Photobucket - Video and Image Hosting
i hope it blows up big enough for you to read it. j
7.3l 99 f-250 SD
post #7 of 11 Old 08-04-2007, 07:54 AM
Got it jason. Though some of your wear numbers are a little high. I have seen much worse with engines nearing 200k. My 2000 has 215K on the clock when I did my last report. My wear numbers are about 1/2 of what yours are. Most of my driving is for longer periods than yours.
My suggestion is to back the interval down to 3k and b4 draining the oil take the truck for a 20 mile cruise down the highway. with the PSD holding about 15 quarts of oil it takes a while for it to heat and cycles through the system. Take your drain as soon as you return from the drive. and take your sample from the middle of the drain. i think you will have a better outcome
As for the coolant, the amount in the oil is only a trace i wouldn't worry about it at this time, but with 200k on it you may be having some Cavation going on in your cylinder. Cavation is small pin holes in the cylinder. 7.3 are natorious for cavation.. Other than that the numbers look good. If you had real bad problems your TBN would have been eaten up.
shawn
post #8 of 11 Old 08-04-2007, 08:36 AM Thread Starter
ok so what is the higest number of tbn is there. i mean like a scale of 0-10 or higher. we are looking to build this thing up next summer. thanks for the insight. j
7.3l 99 f-250 SD
post #9 of 11 Old 08-04-2007, 08:39 AM
Rotella is usually around 10.5, amsoil is pure synthetic and runs a TBN of 12. Lucas has a TBN of 14, but the base stocks arn't that good. Delvac 1 also has a TBN of 12. If you are building it up I would use synthetic with a 12TBN
post #10 of 11 Old 08-05-2007, 08:28 AM
where do you get your oil tested
slandry786 is offline
