Burning Oil - Ford Powerstroke Diesel Forum
Old 05-16-2011, 04:50 PM
Burning Oil
My truck has been burning oil. What are some major things I should look for since it's not leaving an oil spot or anything such as that.
I'm kind of thinking it has to do with the injectors but I'm not really sure
Old 05-16-2011, 08:53 PM
injector orings....my first guess, you could do a compression test to know for sure, how much oil is going bye bye? lol
Old 05-17-2011, 03:09 AM
Subcribed!
I lose about 2+ qts during my 3000 miles between oil changes. I've been wondering about this very subject myself. I use Rotella 15w-40 and Mobil 1 filter, which I dump in to total up my oil drained. I figure in a little for spillage and such as I pour my old oil from my oil collecting drain pan back into the 1 gallon jugs.
Old 05-18-2011, 03:32 PM
I have found my last 2 oil changes have been 2 quarts low over the 4000 mile intervals. I am using Valvoline Premium Blue 15-40. Is this something i should be worried about or is this normal?
Old 05-18-2011, 06:52 PM
its worth a compression test. also look in your fuel bowl, is the fuel color dark? if so thats another of a few indicators that o-rings are bad.
Old 10-04-2011, 12:25 PM
I also have the same issue with my 2002. Can some of you give ideals to what to look for.
It seems like I need to check my fuel bowl for oil. As this might indicate that the injector o-rings are bad.
Anything else I should look for?????
Thanks
Old 10-05-2011, 08:33 PM
Subscribed!
Old 10-05-2011, 11:27 PM
The weird thing is that after ichange my oil it holds constant for 3 or 4000 miles and then it seems as if I have to add a quart every 1000. But I haven't really been taking notes just adding it when it needs it
Old 10-06-2011, 05:21 AM
Somebody has to have an opinion on this.
What do you guys think???
