Best fuel filter - Ford Powerstroke Diesel Forum
Old 05-15-2011, 03:49 PM
Best fuel filter
I will be changing my fuel filter tomorrow to see if it will help increase my fuel mileage. My question is should i go with the Motorcraft or get the Wix? Or is there a better one than either of those? Thanks
Old 05-15-2011, 04:09 PM
Not sure if changing the filter will affect fuel economy too much, but I believe Motorcraft or Racor are the best fuel filters for the 7.3.
Old 05-15-2011, 04:16 PM
Well if the filter is older (only owned the truck a few weeks so i do not know the condition of the current filter) they can hurt fuel economy (not drastically) but even so if the filter is old i need/want to replace it none the less. Thanks for the reply, i will go pick up a motorcraft tomorrow morning then.
Old 05-15-2011, 04:19 PM
i had issues with the fuel filter cap leaking (yes, it was a brand new one along with a new motorcraft filter) so i tried a wix one with the built in top and it seals up fine. i change it every oil change (cheap insurance for my mind that needs peace) so it never gets real dirty.
Vernon
EDIT: yes i know the o ring is made to go only one way. my old cap was leaking so i figured id do a new filter with new cap, still leaked. switched to the wix, no issues now
Old 05-15-2011, 04:27 PM
Never had an issue with the Motorcraft filter and separate fuel filter lid, just make sure to follow the directions and get that o-ring on top right! IIRC the bevel goes up.
Old 05-15-2011, 04:32 PM
ya, we have done plenty of fuel filter changes where i work and never had an issue but for some reason, mine was leaking and then the new filter and cap and still leaked. my pops called me a dumbass and said "you prob put the o ring on upside down".... nope. oh well, wix fixed it.
Old 05-15-2011, 05:09 PM
I've been using the WIX#33818. It has the integrated lid. They've been working fine for me.
Old 05-15-2011, 05:25 PM
Alright then maybe I will get the wix instead. Thanks a lot for the info.
Old 05-15-2011, 05:53 PM
Motorcraft here.
Old 05-15-2011, 07:30 PM
i actually just replaced mine today, along with oil n filter change. motorcraft didn't come with the cap so i got a purolator. it came with cap and o rings. it was very easy to do. took me bout 10 min... no leaks.
