FUEL TANK/ FUEL GAUGE PROBLEM - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-15-2011, 03:45 PM Thread Starter
AnthonyU's Avatar
Quoted: 6 Post(s)
Hey guys heres the deal looking for some help I have a 2003 f 350 and when I run the fuel tank down low and this has happened twice but if the fuel light comes on in 3 - 5 miles I'm dead empty the truck is dead in the water. I bought this truck used so I don't knownifnthentank has been out but I would think that you could run your tank down the light couldncome on and you could go farther then 3-5 miles before you run out any ideas or thoughts or corrective action would be a big help also how do you measure back spacing for wheels I'm trying to put 37's on 22's with a 4" lift without cutting up the truck but the fuel tank/ gauge is really bothering me thanks guys
AnthonyU is offline
post #2 of 16 Old 05-15-2011, 03:54 PM
How about filling it up before it gets that low? They don't really like running with that much fuel anyway.
Austin G is offline
post #3 of 16 Old 05-15-2011, 04:08 PM Thread Starter
AnthonyU's Avatar
Quoted: 6 Post(s)
Yeah I know that I usally fill up with a quarter tank but sometimes thats always not conveinient I should get more miles then I get when the dash light comes on
AnthonyU is offline
post #4 of 16 Old 05-15-2011, 05:10 PM
7.3Lariat's Avatar
You should definitely get a lot more than 3-5 miles after the light comes on. You should still have gallons left. Maybe the sensor piece(not very technical I know) in the tank gets stuck or isn't registering right and so doesn't kick the light on until you have drops left.
______________________________________________
Mike
SOLD
Mods: BD-X monitor, 6637, BTS, GT38R, Snow MPGMax, International up-pipes, Hi-Flow Outlet, 5" Diamondeye, HPx, FRx, Gearhead tunes, Tru-Cool tranny cooler, Remote Start
376HP 791ft-lbs on 10.15.11
7.3Lariat is offline
post #5 of 16 Old 05-15-2011, 05:24 PM
Quoted: 3 Post(s)
might be a cracked fuel pickup tube allowing air into the fuel lines when the tank is low??
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #6 of 16 Old 05-15-2011, 05:29 PM Thread Starter
AnthonyU's Avatar
Quoted: 6 Post(s)
Thanks guys I thought something might be hanging up in the tank does anybody know how fuel is left in the tank when the light comes on I might have to recalibrate everything
AnthonyU is offline
post #7 of 16 Old 05-15-2011, 05:39 PM
i cant help my truck runs out at a quater 2003 7.3 let me know whats up
BlackSheep69 is offline
post #8 of 16 Old 05-15-2011, 06:31 PM Thread Starter
AnthonyU's Avatar
Quoted: 6 Post(s)
Wow thats worse hopefully someone will have an answer for both of us
AnthonyU is offline
post #9 of 16 Old 05-15-2011, 06:37 PM
Depends on short bed / long bed.
With the 26 gallon shortbed tank it comes on with 2 gallons left, the 38 gallon longbed tank comes on with 4 gallons left.
Austin G is offline
post #10 of 16 Old 05-15-2011, 06:48 PM Thread Starter
AnthonyU's Avatar
Quoted: 6 Post(s)
I have the short bd two gallons doesn't seem like alot
AnthonyU is offline
