Starting after long sitting 6 months
I had the starter rebuilt. Took the guy 6mo. Now I have it back on. What do I need to do to get fuel flowing? Turns over good,but no start.
well drain your fuel bowl, who knows how much water is in there, i'd put some kind of additive in fuel that sat that long, and check your hpop res to make sure its full.
you should just turn the key on and let the fuel filter fill up with fuel and it should start right up. if its cranking and not starting check your battery voltage, if there is not a good enough connection it wont start. thats what i would check out first
![]() Some Disel 911 might be in order, too.
Tried all of the above. No start.
check your glow plug relay? check your hpop? fuel in fuel bowl? if all those check good could be a cps?
it took 6 months to rebuild a starter?
Got started ,BIG Thanks to you guys!A girl needs help once in a while. Plan to go back to Hot Shot Hauling.
What did it end up being?
It would help to fill out your sig for future refrence, so people know what your truck and mods are. |
I had cycled the glow plugs several times, had battery charger on, ..... finally gave a whif of wd-40 at air port in grill. Love my truck!
