Injector replacement thoughts
Check engine light came on
engine missing rough running Code came up open circuit on #1 Cyl. replacing injector Ford calls for replacing all injectors and harness Don't want to go broke with injectors What's your thoughts on replacing only one and seeing what happens 2000 Excursion 7.3 with 182,000 miles Mike |
the injector is more than likely not your problem, pull passenger side valve cover off and reconnect harness and see if skip dont go away, and by all means if it is an injector , you can replace just one , work for fordand never heard anybody tel someone they suggest to replace all of them
Your getting ripped off... There is most likely nothing wrong with any of your injectors... Just a bad UVC harness...
