2000 van 7.3 in a 1999 7.3 f250?
i have a 99 f250 super duty with a 7.3 in it and the motor is having problems and i found a motor at a local yard for a nice price but the only thing is that the motor is out of a 2000 ford van..i was woundering if the block and everything are the same because i know the van motors are rated for 215hp and pickup motors are rated for 250 but i know i would have to change the manifolds and everything i was woundering if anyone knew if the motor with all of my stuff such as turbo and manifolds and everything else on the motor will it still have the same power?
To my knowlage, they are the same block and heads... not sure if they have diffrent injectors that might have something to do with the HP rating being diffrent. As long as you use all your bolt on stuff you should be fine.
