'01 F350 gauge problem - Ford Powerstroke Diesel Forum
Old 05-09-2011, 12:48 PM
Gauges would bounce when the truck hit a bump.
Then, boom, all gauges went out completely.
Was told it HAD to be gems module.
Replaced it and...
Still no good
ideas?
Old 05-09-2011, 01:43 PM
Fuse maybe?
How about the plug connectors on the back of the instrument cluster?
Old 05-09-2011, 03:35 PM
Originally Posted by NoRalPh View Post
Fuse maybe?
Checked that before spending $
Old 05-10-2011, 06:02 AM
Do you have the illumination in the cluster? If you had the pin-out of the cluster connector plugs you could at least test for proper power & grounds....
Could be internal to the cluster too, you could open it up and take a look for something obvious. Maybe check the J-Yard for one?
