Boost Questions - Ford Powerstroke Diesel Forum
Old 08-01-2007, 06:03 PM
Boost Questions
Can anyone help me with my boost. Installed guages and boost only gets to 18 at about half throttle and 25 to the floor. Also when the tranny shifts the boosts drops to about 10. Is this normal??
Old 08-01-2007, 06:05 PM
boosting to about 25 isn't bad at all for stock.
Old 08-01-2007, 06:15 PM
trucks not stock though, my info's not coming up. It has a cold air intake, stock exhaust w/cat and muffler delete, banks 80hp chip and a boost tube.
Old 08-01-2007, 06:43 PM
duct tape & zip ties
What year truck, what size engine, are you running any tunes. Those will all make a difference on what your boost will be.
I would say your truck is running normal.
Old 08-01-2007, 07:23 PM
Thanks. 2000 Excursion w/7.3 psd. No tunes yet
Old 08-02-2007, 10:13 AM
If you are at 25 then you have either a chip or a tuner.
Old 08-02-2007, 10:51 AM
I would say it fine i have simalar mods and im right around there maybe a few more lbs i think i can hit 27 WOT. Its fine
Old 08-02-2007, 11:53 AM
Sounds good!
Old 08-02-2007, 05:00 PM
sounds normal to me. i can hit 30lbs of boost with my chip all the way up but i also have a pre turbo exhaust leak so i could have a little more boost but. i wouldnt go much over 25 with the stock turbo
Old 08-03-2007, 05:56 PM
With my stock late 99, all I'm seeing is 11-12 @ full throttle. Judging by your #'s I might have a leak somewhere.
