Fuel Pump Shim.... - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-25-2006, 10:12 PM Thread Starter
PIPE HITTER
gcop's Avatar
Fuel Pump Shim....
I found instructions on how to do this, but they were on 94-97 PSD, mine is a 2k. Anyone know if these are the same?
TA
"Life is hard, it's even harder when you are stupid"
gcop is offline
post #2 of 16 Old 05-29-2006, 10:44 AM Thread Starter
PIPE HITTER
gcop's Avatar
Well I did it, and OMG what a HUGE difference, idle is smoother, throttle response is very crisp, the truck really smokes under WOT, and the best thing about it is the big Ex will spin the tires with authority. :burnout
I shimmed the spring .067 I have not checked the pressure but I would guess it's around 65-70PSI. Eventually I will install an fuel pressure gauge under the hood.
Almost forgot...peak EGT's are down about 150 degrees.
gcop is offline
post #3 of 16 Old 05-29-2006, 02:16 PM
Gun Nut
Rodslinger's Avatar
Quoted: 149 Post(s)
SWEET! Glad to hear it turned out so well buddy. You and I need to go out to Baytown sometime and play with the ricers in the 1/4.
Hey I got back into town later than we had planned on so I'll give you a shout tomorrow.
'05 F250, CC, FX4, 6.0 PSD
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Please support our troops!
Rodslinger is offline
post #4 of 16 Old 05-29-2006, 02:32 PM Thread Starter
PIPE HITTER
gcop's Avatar
No problem Alan, I have been a bit under the weather this weekend, so tomorrow would be better for anyway
Yeah we do need to make a trip to HRP, it's been a while for me.
Oh and other thing worked like a champ, I owe you there for sure.
gcop is offline
post #5 of 16 Old 05-31-2006, 10:03 AM
Ramsmoker's Avatar
Cool Pump shim
If you want to have some fun, usa #6 machine screw so you can turn the pressure up and down for fine tuning. I have found that 95psi and my fuel air seperator have dropped the EGT to 200+ degrees accross the board and widend the power curve like never before.
The Ex -box. Total RSD system. See what happens when you let attorneys run your Country!!!! There's nothing wrong with a Democratic society, we just need to get rid of Democrats. 2001 Excursion. 2003 Cobra Terminator all pumped up. Now this is fuuuuuun.
Ramsmoker is offline
post #6 of 16 Old 06-06-2006, 05:08 AM
FLWHEELIN's Avatar
TA
Where did you find the instructions to to this? and has your mpg changed any?
2005 F350 CC 4X4 DRW - SOLD
ARP head studs
EGR cooler delete
4" Turbo back into stacks
High idle mod
By-pass oil filter
By-pass coolant filter
Banks Six-Gun, PDA, Cold air intake
Zoodad
FLWHEELIN is offline
post #7 of 16 Old 06-06-2006, 09:32 AM Thread Starter
PIPE HITTER
gcop's Avatar
MPG's are unchanged. I am currently doing a tech article on the FPR shim, it's easy. I should have it posted with pics by the weekend.
gcop is offline
post #8 of 16 Old 06-06-2006, 06:51 PM
Ramsmoker's Avatar
Cool Fuel pump shim
If you don't want to play with the shimming there are many places online you can buy a new spring and be done with it in one shot. Not everybody has a claim of what the new pressure is except Gillette diesel service. There spring is advertised to boost pressure up to 95psi. Mine was allready done to 95psi when I came accross there's. Raising the pressure and removing the air from the fuel will be the cheapest power you will do. Removing the air is the only mod I have done that increased power and milage, something every vendor say's there product will do. On top of that , your 7.3 will almost sound like a 6.0!!!
post #9 of 16 Old 06-06-2006, 06:55 PM
dgramenz's Avatar
Send a message via AIM to dgramenz Send a message via MSN to dgramenz
Does a fuel/air separator really make that much of difference in power and mileage? What's the cost? And does it change the sound of the engine that much?
2000 F-250 XLT 7.3, 4x4, SuperCab, short bed, Quadzilla Xzillaraider XZT, K&N air filter, straight pipe, 285/75R16 Mastercraft Courser MT's
dgramenz is offline
post #10 of 16 Old 06-07-2006, 03:10 AM
Moderator
00powerstrokin's Avatar
Send a message via Yahoo to 00powerstrokin
i tried this mod on a friends truck. the only thing that changes was when he got on it the fuel filter cap kkept blowing off. what was i doing wrong
2000 Ford f250 powerstroke. 6 speed, orange ext. cab 4 inch bds lift with 315/75/16 on eagle 589 wheels, k&n, straight pipe, autometer gauges, bully dog 6pos. chip,foil delete, DIY tymar intake, and homemade exhaust brake
00powerstrokin is offline
