relpacing all my injectors,when removing the old ones I forgot to release oil rail drain plug on L/side head (oil is in cly's) do i have to remove head to get oil out befor installing new injectors?
remove all the glow plugs. Bump it over little by little till you complete two revolutions...then bump it over a little faster for two revolutions...then crank it for about 10 seconds with all the glow plugs still out...that will purge the oil for you...
install new injectors then pull glow pugs?
Yes, go ahead an put the injectors in, then remove the glow plugs and turn the engine over.
What they said... Next time just remove the two back injectors, then let it sit for about 3-4 minutes... then remove the rest, reinstall, remove the GP's and turn over... reinstall GP's and your done... Kinda...
