**** should have got a strait shift - Ford Powerstroke Diesel Forum
Old 07-29-2007, 02:16 PM
I noticed on my buddys dodge if he puts it in a high gear like 5th going to slow he can blow smoke until he gets up to speed. Is there anyway to do this on automatic if so how>
Old 07-29-2007, 02:19 PM
IU Hoosier Fan
I don't believe that there is...... if there is I would like to know just for I can tell some people...
Old 07-29-2007, 02:47 PM
i noticed on my truck when you accelarate slowly and it shift into overdrive with the tc locked up you catch in the right spot about 45mph itll roll smoke all day as long as you keep it in overdrive. you push down on the pedal to hard it will down shift and wont blow as much smoke cuz the rpms are to high. i do this alot when people ride my a** itll get them to back up. i dont know if i explained it good enuff maybe youll understand what im talkin about. just keep the rpms low with the overdrive on
Old 07-29-2007, 04:22 PM
all that black smoke is what happens when the turbo is not spooled up enough for the amount of fuel going into the motor, basically it is bogging the motor with more fuel and less air, if the turbo was spooled up the smoke wouldnt be nearly as thick.
Old 07-29-2007, 04:24 PM
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Let it shift into OD, ease into but not all the way......it will roll until the spinny thing spools......
Old 07-29-2007, 04:34 PM
yeah thats what i was tryin to say itll blow coal as long as you what if you work the throttle just right i do it all the time
Old 07-29-2007, 06:50 PM
Holding the brake helps too, but the turbo will still spool if you are giving it enough fuel.
