Dreaded oil pan gasket - Ford Powerstroke Diesel Forum
post #1 of 17 Old 04-14-2011, 03:49 AM Thread Starter
wadmalawjoe's Avatar
Well it looks like its time to replace the oil pan gasket. The only way to do this is by taking the motor out?
I have never taken a motor out, I have changed transmissions and such.
Is it possible to clear off the turbo and such, then hoist the motor up enough to take out the oil pan? or, By the time I have gotten it to that point I might just as well take it out?
I am thinking of taking it somewhere and having it done, however, if I took it out I would be able to do so many other things while its out. Like clean everything up, paint it both the motor and engine bay, not to mention fixing or replacing various other things while its easy to work on. It would be a good time to change the exhaust out etc etc. I have a somewhat limited work space, I have a horse farm with a barn, but I board horses. So my boarders would be a bit weirded out by a disassembled truck in the horse barn. I wouldn't care but......they provide a nice income for me so I don't have to work so much The tractor shed has a dirt floor and low ceiling, I could do under the old oak tree thing, but, then if it rains.......
I am thinking it would take me a week at least, since it would be my first engine removal, plus all the little side projects I would want to do while its out (clean up,paint,exhaust etc).
Any thoughts or input?
Truck; late 99 F350 SRW, 7.3, 2wd
Glowshift pillar gauges,boost,trans,egt
Riffraff air intake kit
CCV mod
Foil delete
Intake heater delete
Python remote start/alarm
Other work horse;
Ford 3000 tractor
Name; Joe
wadmalawjoe is offline
post #2 of 17 Old 04-14-2011, 04:00 AM
where on the pan is it leaking? front, back or sides?
2008 6.4 f250 lariat 4wd
melmount is offline
post #3 of 17 Old 04-14-2011, 07:21 AM
Zaairman's Avatar
Quoted: 12 Post(s)
Why do you think it's the oil pan gasket? Those gaskets very rarely fail... But, yes, you need to pull the motor. If there is any rust at all on the oil pan, replace it.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #4 of 17 Old 04-14-2011, 07:29 AM
Shade tree mechanic
95dieselsmoke's Avatar
Just make sure its the oil pan before going any farther. Many other common leaks to look for before the oil pan is the positive suspect.
MATT
Now featuring a 6.4 fat bottum 6 speed
95 f250--238k and counting
RDS stage I's-TW live tuned-Dana 60 swap-9" lift/40x13.5x20 ProComps-ZF5 swap/short throw/South Bend CON OFE-Iron Bull front-AFE CAI-SD innercooler-Fab Tech traction bars-MBRP DP/6" black miters-Autometer boost/pyro
"If you dont have ambition and big dreams, you end up working hard for someone who does"
95dieselsmoke is offline
post #5 of 17 Old 04-14-2011, 02:29 PM Thread Starter
The leak seems to be coming from the front passenger side of the oil pain. That little 1 inch or so flat spot right before it dips below crankshaft. I am second guessing myself, since a couple on here said to look carefully and a highly recommended mechanic I talked to today said to look carefully because those oil pan gaskets very rarely leak. The pan is put on there to stay. I'm going to clean it up some more and try to get as close as I possible can to the area while its running and see.
I will report back with my findings as soon as I can.
Thanks again everyone!
CCV mod
Foil delete
Other work horse;
Ford 3000 tractor
Name; Joe
post #6 of 17 Old 04-14-2011, 02:34 PM
Buffalo444's Avatar
yeah, they're more likely to rust through than bust that gasket. IMO though, if you do have any o.p. gasket/ rust problems, id put on a new one that is coated HEAVILY in undercoating. Not that cheap flakey stuff either. Dont wanna hafta re-do it.
Jason
First rig: e99 F250 CCSB 4x4 auto, white, 388k miles: traded in
Then: 02 F350 RCLB SRW 4x4 zf6, silver, 201k miles, THREW A ROD
: traded to Jake
Now: 96 F350 CCLB DRW 4x2 auto, red and silver/grey, 266k miles: rusty but trusty
Buffalo444 is offline
post #7 of 17 Old 04-14-2011, 09:23 PM
Quoted: 2 Post(s)
I swore up and down Mine was leaking and could see it drip out, no trail nothing no oil in the valley. Mine ended up ebing the EBPV rod. blowing straight back ontop of the trannyand drippign down somehow to the oil pan by the starter.
Do you have oil leaking from the trans cross member? Mine was leakign from all over the trans from beign blown over top of it. When I took the pedestal off I couldnt believe how much oil was on top ot the trans in all the hiding spots... couple hours and some cleaner and it shines again though
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-DieselSite Transmission Filter
--W/ Guage and Flush valve
-Factory Tech Valve Body
-Stage 2 Snow Performance Water Meth
-AFE Blade Runner Intake Manifold
-TurboMaster WasteGate Control
-DieselSite Boost Relief Valve
-AIH Delete
-Garrett High Flow Outlet
-Garrett NON-EBPV Pedestal
-Plenum Inserts
-Torque Converter Lock Up Switch
cesspool is online now
post #8 of 17 Old 04-17-2011, 05:35 PM Thread Starter
Well I cleaned it up really good and got plenty of lighting set up.
The leak is in between the timing cover and oil pan at that little flat spot right before it dips under the crankshaft.
So everything gets pulled off the front to get to it. It drips about 1 quart for every 150 miles probably. Its making a mess underneath, oil spots everywhere from airborne drops.
I'm hoping to do while its in the truck.
I plan on changing out the water pump while its off, any other suggestions?
or any other thoughts?
CCV mod
Foil delete
Other work horse;
Ford 3000 tractor
Name; Joe
post #9 of 17 Old 04-17-2011, 07:06 PM
the motor must be pulled to change the oil pan, no other way has worked well.. anyway water pump is good, put a coolant filter on too.
Dietoremain is offline
post #10 of 17 Old 04-17-2011, 07:14 PM
sethc24's Avatar
Pulling the motor is not too bad honestly. I took off the bumper,grille,headlight panel,radiator,IC etc. And me and my dad just pulled it straight out the front. Was not bad at all. Even though my oil pan was not in bad shape i replaced it with a new one anyways. Its also a good time to replace the dipstick gauge adapter nut and o-ring.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
