Runnnn away 7.3, then....boom. - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-11-2011, 10:48 PM Thread Starter
long story short got a bud with a 7.3, had a turbo go bonkers, the motor ran away and over revved by itself, ate up the turbo, so he replaced a piston(everything else checked out), put it all back together new turbo and all... got it to run then it just died.
swapped IDM's, nope not that. IPR is good as well.
Ran on ether(dumb dumb i know i wouldnt) and really rough, put a gauge on the oil rail and got 600psi at idle and max 1300 psi revving..
Im thinking its possible the hpop did get damaged revving the motor up that high and out of control, what do you all think?
Thanks..
EDIT: also tons of white smoke when they got it to run on ether for a few minutes. Also managed to pull a code with the superchip and it was the ICP low code, sounds like its time for a hpop.
Dietoremain is offline
post #2 of 11 Old 04-12-2011, 04:57 AM
Quoted: 3 Post(s)
sucks, man sorry to hear that. They sure it wasnt like an injector stuck open, how would the turbo cause the truck to rev itself?
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 11 Old 04-12-2011, 06:02 AM
mxfever090's Avatar
All of our old tractors puff white when you assist start with ether. So I don't know if I would be concerned with that.
Bigger concern would be what would cause the motor to run away?
Jason
O.T.F.D. Volunteer 19
Great White - 2003 7.3l F-250 4x4 CCSB -102,000 miles and tickin
DIY intake - 4" Straight pipe - HPX - CAT ELC - 203 t stat - billet t stat housing - coolant filter - dual alt radiator hose - 12V Air compressor - 5 gallon air tank - Air line quick connects - AIR HORNS!
Hers: 2013 VW Jetta TDI
mxfever090 is offline
post #4 of 11 Old 04-12-2011, 06:08 AM
justinlogue5_0's Avatar
This may be a dumb question so sorry if it is but why wouldn't the rev limiter have kept it from over reving? I would understand the dieseling but not over reving?
If your getting 600 at idle, I would think you should be able to idle pretty nice and just not have any power, right?
A little bit of this and a little bit of that. I want a lot more of this and a lot more of that
It never ends!
justinlogue5_0 is offline
post #5 of 11 Old 04-12-2011, 06:23 AM
ridiculously_necessary's Avatar
icp, ipr or hpop are my thoughts.
have you check compression in all cylinders?
justin - the runaway was likely cause by self fueling, leaky injector or oil getting into the cylinders or intake, so no control over fueling.
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #6 of 11 Old 04-12-2011, 07:18 AM
That makes since now. Hard for a computer to shut it down when its bypassing every thing. Thanks
It never ends!
post #7 of 11 Old 04-12-2011, 07:30 AM
MUDSTROKIN''s Avatar
Diesel engine "run away" is usually when the turbo seals let loose, letting oil into the cylinders. The oil ignites and and continues to burn and makes the engine take off out of control because you're not controlling the "fuel" intake by the engine. It's feeding itself, therefore, you can't stop it you're just along for the ride.
2005 F250 Reg cab LB XL
Airaid CAI
4" MBRP straight pipe from the turbo back.
RCD EGR Delete
Upgraded Banjo Bolts
Zoodad Mod
Swamps HOT FICM
Lariat Captains Chairs with woodgrain center console
MUDSTROKIN' is offline
post #8 of 11 Old 04-12-2011, 07:35 AM
Thanks..
Did you re-ring the whole motor while you had it down? If not I would definetly run a compression test on it to eliminate that. If that checks out then its probably some thing a little more simple like ridiculously_necessary was asking about.
It never ends!
post #9 of 11 Old 04-12-2011, 09:10 AM Thread Starter
thankfully not my truck, a friends, and he replaced a piston and reinged the one, did a compression test on everything that was the only one that was low which he replaced.. now this happened... so yeah im leaning towards HPOP for sure now.
post #10 of 11 Old 04-12-2011, 02:40 PM
Feedback Score: 5 reviews
Did he pull the ICP and check it? Run it w/ the ICP unplugged?
I would just check that before the HPOP.... but it does kinda sound like it.
ToMang07 is offline
