What should be my next mod? - Ford Powerstroke Diesel Forum
Old 04-11-2011, 06:47 AM
1) precision turbo, if so should I do the high flow outlet with ebpv delete or just the charger. I'm onnly running max of 21 pounds of boost
2) The stealth hpop mine is putting out around 3100 psi a full throttle
3) Regear with 4.30's, my front axle has a small roar in it.
Old 04-11-2011, 08:23 AM
I probably would go with the turbo, but might check into the front axle
