best shocks for my X - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-08-2011, 01:21 AM Thread Starter
Quoted: 2 Post(s)
whats the best shocks for the excursion? 2000 jsut turned 60K. I tow alot and the stockers are bout dead...
no lift at all and it will stay stock height
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-DieselSite Transmission Filter
--W/ Guage and Flush valve
-Factory Tech Valve Body
-Stage 2 Snow Performance Water Meth
-AFE Blade Runner Intake Manifold
-TurboMaster WasteGate Control
-DieselSite Boost Relief Valve
-AIH Delete
-Garrett High Flow Outlet
-Garrett NON-EBPV Pedestal
-Plenum Inserts
-Torque Converter Lock Up Switch
cesspool is offline
post #2 of 9 Old 04-08-2011, 12:52 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Bilsteins..but don't expect much improvement without changeing at least the front springs so you have some compression travel.
CT Performance, Inc. is offline
post #3 of 9 Old 04-08-2011, 04:57 PM Thread Starter
Quoted: 2 Post(s)
what springs? and which Bilsteins?
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-AIH Delete
-Plenum Inserts
cesspool is offline
post #4 of 9 Old 04-08-2011, 05:01 PM
Quoted: 3 Post(s)
PM sent.............
post #5 of 9 Old 04-08-2011, 05:17 PM Thread Starter
Quoted: 2 Post(s)
any other suggesstions
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-AIH Delete
-Plenum Inserts
cesspool is offline
post #6 of 9 Old 04-08-2011, 06:09 PM
JEL
Originally Posted by cesspool View Post
anyone with a more reasonable less than $3,000 suggesstion
Bilsteins will be the best choice and should run you just about $65 each shock, give-or-take a couple of bucks. I recommend the yellow body shocks, I have those on my Tundra and they are fantastic shocks.
JEL is offline
post #7 of 9 Old 04-09-2011, 06:22 AM
Quoted: 3 Post(s)
..as I said in my PM just a front spring change to V codes would do wonders..$350-400 pair at the dealer..
post #8 of 9 Old 04-09-2011, 08:15 AM
Im currently running the yellow body bilsteins on my 00 SD and am more than happy with them, bout $65 apiece.
Jim
2000 7.3l 4x4 6sp
DIY intake
4" exhaust
6pos by Dyno Proven
Wicked wheel
160cc
Honey Badger jr
custom clutch
Auto Meter Z series gauges
jimmyp is offline
post #9 of 9 Old 04-09-2011, 08:36 AM
Spend a bit more and get the Bilstein 5150's. I love them. Have had them on several vehicles that Ive owned, and it never ceases to amaze me the change in ride it makes.
2001 Ford F-250 Super Duty
7.3 Powerstroke - ZF-6 speed - 6" lift - Bilstein 5150's - 35's - 4" Magnaflow exhaust - Superchips 1705 - AFE Stage 2 intake - Isspro gauges - HPX line - 203* T-stat, Billet housing - Bypass coolant filter - Bypass oil filter - Stancor GPR - High Idle Controller - International 'blue' CPS - non-EBPV pedestal/exhaust housing - Wicked Wheel - CCV mod - Boost Fooler - 06 Harley lights - T500 HPOP - Valair Clutch
-Nathan- is offline
