quick disconnect heater hoses - Ford Powerstroke Diesel Forum
Old 04-07-2011, 09:03 AM
It appears I have a small leak where the heater hose quick disconnect to the heater core at the firewall is.
I get the plastic clips yu press to pull out the hose but is there an Oring in there somewhere? What seals it? I guess it could also be wherfe the metal is crimped to the hose? Anyone experience this?
Old 04-07-2011, 09:19 AM
I just posted about this. Mine leaked as well. There is a plastic ring as well as an o-ring. You can buy new quick connects from Rockauto.com for 15$ or you can do like I did and get 5/8" barbs, heater hose and hose clamps and never worry about them leaking again.
Old 04-07-2011, 09:30 AM
will the new 5/8 quick disconnects come with the 0-ring? Are they both 5/8 or is one 3/4?
Des it need o be special for ford or are all the heater hopse connects the same for chevys too? Loal part store has them but not sure if they are the same?
Old 04-07-2011, 09:37 AM
yes will come with new o rings. Both are 5/8. Not sure about the chevy ones.
